emmc module help
Just bought my first rock64, and planning on buying more to replace some if not all of my raspberry pi's.
I bought a 1gb model for testing purposes and basically because it was so cheap, and it looks like the best and fastest option for running the os is an emmc card.  So here is my question, if that is the case and emmc is the best option, what's the deal with the color code systwm for emmc's?  This board will replace my raspberry pi 3B that I'm running nextcloud and plex media server on,  and I should be able to use a 16gb emmc module.  I have no idea which one I should buy though, a blue dot, a white dot, a red dot, what does all that mean and which one do I need?  Thanks in advance for the help, looking forward to getting this board up and running.
(04-04-2019, 10:05 PM)default_user8 Wrote: I should be able to use a 16gb emmc module.  I have no idea which one I should buy though, a blue dot, a white dot, a red dot, what does all that mean and which one do I need?
Not sure what the dots mean, but I bought 2 64GB eMMC modules and the USB programmer - and somehow, I have no idea why - one of the eMMC's can only be seen as a 16GB MSDOS partition - and nothing on this earth has been able to get it back to a plain 64GB chip.
At this rate I'm sticking with microSD's until I can figure out what makes bricking a 64GB eMMC so easy.
Question Compatible eMMC modules and benchmarks danboid 7 26,471 03-09-2023, 08:14 AM
Last Post: arvendui
Question Have eMMC adapter - but can't seem to fix eMMC card SirRyanTheGeek 3 11,935 05-04-2019, 04:19 AM
Last Post: burito111
  Using ESP32 as WiFi and Bluetooth Module shripal17 2 7,149 03-08-2019, 02:44 AM
Last Post: shripal17
  Dead eMMC? machina 8 16,209 11-21-2018, 05:05 AM
Last Post: machina
  FORSEE eMMC is reliable? ramprasad 3 8,972 11-12-2018, 03:34 PM
Last Post: Tortax
  can a SD card be used as storage with emmc boot Enzo 9 22,585 05-10-2018, 08:53 PM
Last Post: pfeerick
  Flashing full image to eMMc with a mSD card to eCMM adapter pytheas 2 6,598 04-09-2018, 03:56 AM
Last Post: Luke
  Prb booting emmc darthyoh 12 22,469 03-22-2018, 07:07 PM
Last Post: pfeerick
  eMMC angelscream09 2 6,317 02-05-2018, 08:36 AM
Last Post: Luke
  wifi module zehks 5 9,981 12-19-2017, 11:56 PM
Last Post: zehks
