wifire pci
Try to connect wifire pci card, but rockpro doesnt boot with it, is any opportunity to use it, or not.supported?
Sorry i mean fire-wire pci card of course
(02-05-2019, 08:20 PM)orlovnv Wrote: Sorry i mean fire-wire pci card of course
ROCKPro64 accepts PCI-e card, not PCI card.
i
i try Espada PCIe1394a card it doesn't work
i
Hello orlovnv,
driver for ASMedia bridge ASM1083, plus FireWire Via Technologies VT6307L ?
Check if you have the 'firewire-ohci' driver loaded with:
lsmod|grep -i 'fire' --color
If not create , or add:
# cat /etc/modprobe.d/firewire.conf
options firewire-ohci debug=2
then reboot and check again..
Also check the message logs, after boot:
dmesg|grep -Ei "fire|ohci|wire|fw" --color
I followed this topic, its better if you can look at it here.
Best Regards
Users browsing this thread: 8 Guest(s)
