Hardware Accelerated Video Playback Guide
Hey all,
With the help of MrFixit2001, I was able to come up with a recipe for playing hardware accelerated media files with MPV. I'm using MrFixit2001's image as a starter.
Flash this image to an SD card (Etcher) https://github.com/mrfixit2001/debian_bu...xit.img.xz
ssh or access the terminal with a keyboard (root/root or rock/rock)
apt update && apt install vim git libdrm-dev vainfo libmodplug1 libmodplug-dev libmp3lame-dev libmp3lame0 libopus0 libopus-dev libspeex1 libspeex-dev libtheora-dev libtheora0 libghc-bzlib-dev libass5 libass-dev autoconf automake libtool libasound2 libasound2-dev libpulse-dev cmake debhelper fakeroot libvorbis-dev python git clone https://github.com/rockchip-linux/mpp --depth 1 -b release git clone https://github.com/rockchip-linux/ffmpeg --depth 1 -b rockchip/release/4.0 git clone https://github.com/mpv-player/mpv --depth 1 -b v0.29.1 cd mpp cmake -DENABLE_VP9D=ON -DRKPLATFORM=ON -DENABLE_AVSD=OFF -DENABLE_H263D=OFF -DENABLE_H264D=ON -DENABLE_H265D=ON -DENABLE_MPEG2D=ON -DENABLE_MPEG4D=ON -DENABLE_VP8D=ON -DENABLE_JPEGD=OFF -DHAVE_DRM=ON wget https://raw.githubusercontent.com/LibreELEC/LibreELEC.tv/master/packages/multimedia/rkmpp/patches/rkmpp-0001-fix-32-bit-mmap-issue-on-64-bit-kernels.patch patch osal/allocator/allocator_drm.c rkmpp-0001-fix-32-bit-mmap-issue-on-64-bit-kernels.patch make -j6 && make install cd ../ffmpeg ./configure --enable-static --enable-shared --enable-cross-compile --cross-prefix=/usr/bin/arm-linux-gnueabihf- --sysroot="/" --sysinclude="/usr/include" --host-cc="/usr/bin/gcc" --arch="arm" --target-os="linux" --disable-stripping --pkg-config="/usr/bin/pkg-config" --prefix=/usr --enable-avfilter --disable-version3 --enable-logging --enable-optimizations --disable-extra-warnings --enable-avdevice --enable-avcodec --enable-avformat --enable-network --disable-gray --enable-swscale-alpha --disable-small --enable-dct --enable-fft --enable-mdct --enable-rdft --disable-crystalhd --disable-dxva2 --enable-runtime-cpudetect --disable-hardcoded-tables --disable-mipsdsp --disable-mipsdspr2 --disable-msa --enable-hwaccels --disable-cuda --disable-cuvid --disable-nvenc --disable-avisynth --disable-frei0r --disable-libopencore-amrnb --disable-libopencore-amrwb --disable-libcdio --disable-libdc1394 --disable-libgsm --disable-libilbc --disable-libopenjpeg --disable-libvo-amrwbenc --disable-symver --disable-doc --disable-w32threads --enable-asm --enable-bsfs --enable-bzlib --enable-demuxers --enable-encoder=aac --enable-encoder=ac3 --enable-encoder=mjpeg --enable-encoder=png --enable-encoder=wmav2 --enable-filters --enable-gpl --enable-libspeex --enable-muxer=adts --enable-muxer=asf --enable-muxer=ipod --enable-muxer=mpegts --enable-muxer=spdif --enable-parsers --enable-pic --enable-postproc --enable-protocol=http --enable-pthreads --enable-shared --enable-swscale --enable-yasm --enable-zlib  --enable-gpl --disable-nonfree --enable-ffmpeg --enable-ffplay --disable-avresample --disable-ffprobe --enable-postproc --enable-swscale --enable-indevs --enable-outdevs --enable-pthreads --enable-zlib --enable-bzlib --disable-libfdk-aac --disable-gnutls --disable-openssl --disable-libopenh264 --enable-libvorbis --enable-muxer=ogg --enable-encoder=libvorbis --disable-vaapi --disable-vdpau --disable-mmal --disable-omx --disable-omx-rpi --enable-libdrm --enable-version3 --enable-rkmpp --disable-libopencv --enable-libopus --disable-libvpx --enable-libass --disable-libbluray --disable-librtmp --enable-libmp3lame --enable-libmodplug --enable-libspeex --enable-libtheora --disable-libwavpack --enable-libfreetype --enable-fontconfig --disable-libx264 --disable-libx265 --disable-yasm --disable-mmx --disable-sse --disable-sse2 --disable-sse3 --disable-ssse3 --disable-sse4 --disable-sse42 --disable-avx --disable-avx2 --disable-armv6 --disable-armv6t2 --enable-vfp --enable-neon --disable-altivec --extra-libs=-latomic --enable-pic --cpu="cortex-a53" --pkgconfigdir=/usr/lib/arm-linux-gnueabihf/pkgconfig make -j6 && make install cd ../mpv ./bootstrap.py ./waf configure && ./waf && ./waf install  mpv --vo=gpu --gpu-context=drm --hwdec=rkmpp your_media_file.mp4
I haven't run through the guide a second time on a fresh image, so if you run into issues, let me know and I'll edit this. I'm working on creating a guide on the bionic minimal image from Ayufan next, but I'm running into a few issues.
update: change your url on the 32-to-64 patch to https://raw.githubusercontent.com/LibreE...nels.patch. It's missing in the current version.
question: Why set the cpu descriptor as a53? We also have two a72 cores to work with.
Why there is no such solution for every distro for Rock64?
  RockPro64 linux console video mode callegar 0 2,973 09-06-2022, 02:32 PM
Last Post: callegar
  Video playback hiccups with Fedora 35 on RockPro64 whitecat23 4 8,888 02-01-2022, 03:35 PM
Last Post: whitecat23
  WORKING: GPU-accelerated Widevine Chromium for Ubuntu 64 twilite 0 4,138 09-13-2021, 11:02 AM
Last Post: twilite
  Netflix with hardware acceleration not working Helium75 1 5,327 12-15-2019, 09:26 AM
Last Post: Helium75
Information [archived] 0.8.X images from ayufan; Mate DE + video / 3d acceleration Luke 28 59,218 05-18-2019, 02:03 PM
Last Post: rickard
  Grabbing screenshot while hardware decoding StefanRvO 0 3,066 05-16-2019, 09:01 AM
Last Post: StefanRvO
  hardware pwm pins Mentaluproar 1 5,036 02-24-2019, 02:09 AM
  Video playing Faster NightCrawler504 8 15,589 12-07-2018, 09:50 AM
Last Post: fosf0r
  Hardware Graphics Accelerator RuslanGennadievich 1 4,611 09-25-2018, 02:43 AM
Last Post: dukla2000
