ibEGL.so libmali-rk-utgard-450-r7p0:arm64 1.6-1ayufan10
how on earth do you get around this?
rock64@rock64:~$ sudo apt --fix-broken install
Reading package lists... Done
Building dependency tree
Reading state information... Done
Correcting dependencies... Done
The following package was automatically installed and is no longer required:
  libopts25
Use 'sudo apt autoremove' to remove it.
The following additional packages will be installed:
  libglvnd-dev
The following NEW packages will be installed:
  libglvnd-dev
0 upgraded, 1 newly installed, 0 to remove and 0 not upgraded.
163 not fully installed or removed.
Need to get 0 B/3412 B of archives.
After this operation, 25.6 kB of additional disk space will be used.
Do you want to continue? [Y/n] y
(Reading database ... 116454 files and directories currently installed.)
Preparing to unpack .../libglvnd-dev_1.0.0-2ubuntu2.2_arm64.deb ...
Unpacking libglvnd-dev:arm64 (1.0.0-2ubuntu2.2) ...
dpkg: error processing archive /var/cache/apt/archives/libglvnd-dev_1.0.0-2ubuntu2.2_arm64.deb (--unpack):
 trying to overwrite '/usr/lib/aarch64-linux-gnu/libEGL.so', which is also in package libmali-rk-utgard-450-r7p0:arm64 1.6-1ayufan10
Errors were encountered while processing:
E: Sub-process /usr/bin/dpkg returned an error code (1)
rock64@rock64:~$
help is greatly appreciated
(01-25-2019, 12:24 PM)KC7NOA Wrote: how on earth do you get around this?
  libopts25
  libglvnd-dev
  libglvnd-dev
rock64@rock64:~$
You should be able to get round it by using --force with dpkg
dpkg --force-help
  Screen lock fail Bionic-lxde-rock64-0.7.8-1061-arm64 electrique 0 3,651 12-28-2018, 11:00 PM
Last Post: electrique
  arm64 package missing - libjpeg8-dev Mentaluproar 1 4,300 11-12-2018, 10:33 PM
Last Post: evilbunny
  updating 0.6.41 arm64 packages on 0.5.15 jata 1 3,906 05-29-2018, 12:28 PM
Last Post: i69fstop
  Debian Mate arm64 0.5.15 - mouse polling rate S3phi40T 0 2,894 02-10-2018, 02:08 PM
Last Post: S3phi40T
  setup root on stretch arm64 ayufan jata 4 10,025 12-08-2017, 02:19 AM
Last Post: jata
