03-17-2016, 11:11 AM
how can you use Raspberry Pi 2 modules or extensions on the Pine? e.g. the products of
http://www.sunfounder.com/
sunfounder modules
03-30-2016, 06:39 AM
Not sure about every product, but i think most of the kits use breadboards and GPIO, so i would assume they would work, as the GPIO pins on Pine64 are the same as Raspberry Pi 2. It should work if you can control GPIO pins using Linux... @tllim , can you confirm this?
If I've helped you with something, please leave a rating for my responses.
03-30-2016, 09:49 AM
(03-17-2016, 11:11 AM)norm24 Wrote: how can you use Raspberry Pi 2 modules or extensions on the Pine? e.g. the products of Due to the robot has limited physical space, the current Pine A64 may not fit in. (03-30-2016, 09:49 AM)tllim Wrote:(03-17-2016, 11:11 AM)norm24 Wrote: how can you use Raspberry Pi 2 modules or extensions on the Pine? e.g. the products of I was thinking more of the modules such as this set http://www.sunfounder.com/catalog/produc...egory/103/ or this http://www.sunfounder.com/starterkit/rpi...sorv2.html I think that's good if someone wants to learn programming |
