Remix OS
#31
(03-21-2016, 08:50 AM)janjwerner Wrote: I had no problems with Remix rebooting. It works smoother than the Android image shipped in BSP.
Only downside with Remix so far is lack of Google app store (I tried installing it last night but it hangs...)
as for the cables I would go with: http://www.amazon.com/gp/product/B018IAXSS4.
Look at AWG rating - the lower the better -  20 for Tronsmart cables,
28 for Amazon Basics cable - sadly I was expecting better quality from AMZ...
I guess your keyboard is in one of three langages initially proposed?
We custom made a  power only USB cable (means no data lines) for backerkit folks, such cable normally does good job on supply power.
For Amazon, I may try out such cable: http://www.amazon.com/PortaPow-Specialis...+usb+cable
On the Google store app, I also notice lacking on the beta build, will check with Remix folks whether able to add in. I will meet up with them at Beijing on early April. If there is any suggestion about Remix OS beta build, please post here. I will collect and feedback.
TL LIm, I got in touch with the guys of Remix and they told that 2GB RAM is a minimum requirement for the OS to run smoothly. Personally, I wouldn't mind as my boards will come with 2GB but what about those with 1GB boards?
Remix prefer 2GB DRAM for better user experience. If backer try out on 1GB board and satisfy on the performance, then they can continue use the Remix.
Thanks for confirming this.
I had that debate with a backer over at the KS comments. He claimed that the 1GB board can handle the REMIX OS with no problems. This is why I had to ask the official REMIX about that.
If you don't want to deal with Phoenix card below is the link to dd image of remix burned to 32gb card
https://drive.google.com/file/d/0B_6QLyX...sp=sharing
As noted above it works OK with 1gb of RAM, I bet the experience will be better with 2gb boards. This image does not contain google app store.
You can try to follow the instructions on http://forum.xda-developers.com/remix/re...x-t3292087
It did not work for me, but hey I'm a big android noob Wink
(03-23-2016, 01:02 PM)janjwerner Wrote: If you don't want to deal with Phoenix card below is the link to dd image of remix burned to 32gb card
I have feedback to Remix OS about lacking PLAY store app, hopefully they will make a new release soon.
Looks like the Google PLAY store app released on XDA site is for x86 version.
Already have feedback from Remix OS, they will release new build with Play Store feature soon. For current Remix build, you will get the Play Store app thru OTA when released.
Just received new build from Remix and PLAY store already supported :-) We are currently testing this build for few days before release out.
... TL Lim
... TL Lim
UVC support?  Big Grin
... TL Lim
Not yet, Remix mentioned not hard to port in UVC driver and Remix Mini box already supports UVC.
... TL Lim
Great! (y)
  sourround sound - Remix MrSarkasmus 0 3,731 10-05-2018, 05:05 AM
Last Post: MrSarkasmus
Star Remix OS 2.0 Image Release 20160718 tllim 25 53,607 08-30-2018, 01:21 PM
Last Post: Idemdesign
  Remix os os 64bits ?? Matroxplay 1 5,467 07-14-2018, 11:48 AM
Question Nginx proxy on Remix OS -- possible? mitchmitchell 1 5,934 05-29-2017, 02:45 AM
Question Remix OS 2.0 [20170105] Waaaa??? veronicasmithen03 1 5,830 05-29-2017, 02:42 AM
  REMix OS Boots and then blank Screen Michaelrowe01 6 22,254 04-17-2017, 04:20 AM
Last Post: simplexdan
  Stuck at Remix OS logo leongzhi 9 28,585 12-21-2016, 08:09 AM
Last Post: Michaelrowe01
Exclamation LCD TOUCH SCREEN PANEL support in Remix? mcfly777 4 10,991 12-19-2016, 07:49 PM
Last Post: Toriless
  Guest Account in Remix OS cannot Get Internet Connection deniyulianti 1 5,292 10-15-2016, 07:16 AM
Last Post: MarkHaysHarris777
  No microphone input in Remix xtcrefugee 3 12,131 08-19-2016, 06:24 PM
Last Post: jkmooney
