Clarification of type-c superspeed device mode
Hi everyone,
The Rock64Pro looks like it would make for a perfect home made nbase-t usb3 adapter, assuming that the type-c port can operate in peripheral superspeed mode. Some parts of the website indicate that the type-c port has otg support in which case I think it would be the Rock64pro would be able to behave as usb device for another computer. Also it is unclear whether the usb-c port operates in superspeed mode as either a host or a peripheral. Can someone confirm that it will behave as a superspeed peripheral?
Assuming that it can act as a superspeed type-c peripheral, then it may be possible to install an 10Gbe ethernet card into the x4 slot and turn the whole thing into a 10Gbe type-c ethernet adapter.
Does anyone see any obvious obstacles to this idea?
(06-23-2018, 09:18 PM)cpwrunner Wrote: Hi everyone,
Seems possible, just need the driver support.
Could you elaborate a little more? Have you used the rock64pro as a usb 3 peripheral? Are you saying that I would need driver support for the 10Gbe ethernet card?
Short answer: You need drivers for all peripherals, regardless of connection. They don't magically work because they're connected to a supported port. Some os'es come with a plethora of drivers preinstalled and some distros come with specialized drivers for certain peripherals. If you're lucky, you can find a driver for your 10Gbe pcie card on aarch64 architecture, it'll work.
(07-01-2018, 03:38 AM)CaptainZalo Wrote: Short answer: You need drivers for all peripherals, regardless of connection. They don't magically work because they're connected to a supported port. Some os'es come with a plethora of drivers preinstalled and some distros come with specialized drivers for certain peripherals. If you're lucky, you can find a driver for your 10Gbe pcie card on aarch64 architecture, it'll work.
Ok, but my question only partly deals with software support. The other part of my question is a clarification of the type of usb type c port which is available on the RockPro64.
- Is the usb type-c port OTG? Can it act as a peripheral in addition to acting as a host? (this is only a partly a question about software, it is also a question about the hardware capabilities of the rockpro64)
- If the type-c port can act as a peripheral, can it do so at super speed?
  Best device image for docker usage? Dreamwalker 1 3,243 05-01-2022, 04:08 PM
  Device unable to boot Lunix33 9 12,608 09-23-2021, 01:38 AM
Last Post: LMM
  Second screen with usb type-C cricket 0 2,319 07-07-2021, 10:30 AM
Last Post: cricket
  Device bricked? TheHunter 1 3,981 03-10-2021, 05:27 PM
Last Post: TheHunter
  USB Device Mode R0b0t1 3 20,539 10-30-2020, 07:34 PM
Last Post: guannais
  PCIe x4 mode - Lane 3 failure acdkyn 1 4,836 04-24-2020, 01:32 PM
Last Post: kuleszdl
  USB Type-C Display cable support (for 2 in 1: Video + Power) Paprika88 0 3,633 02-12-2020, 06:47 AM
Last Post: Paprika88
  Non burst mode in MIPI DSI skumar 0 3,114 06-06-2019, 12:54 AM
Last Post: skumar
  rock64pro - using gigabit ethernet dongle on usb type C dkebler 2 8,761 09-07-2018, 12:41 AM
Last Post: steamiestoyster
