Flashing full image to eMMc with a mSD card to eCMM adapter
FWIW
I failed to order the Pine USB Adapter for eMMC Module when ordering my Rock64.
https://www.pine64.org/?product=usb-adap...mmc-module
Due to the shipping rate to Europe, ordering it later from Pine was  not an option.
So I turned to the Odroid microSD to eMMc adapter sold by Amazon at a more reasonable shipping rate.
https://www.amazon.fr/ameriDroid-eMMC-Ad...B01LHJ2O38
or
https://www.amazon.com/ODROID-eMMC-Adapt...B01LHJ2O38
Using Win32DiskImager, I uploaded the 32 GB microSD Bionic full image I have been using to my Windows 10 PC .
I then formatted (Full Erase (which failed), then Quick Erase) the Pine 64 GB eMMc (using the microSD adapter fitted into an SD adapter) with SDFormatter.
Last, I used Etcher to flash the Bionic image back to the eMMC card (using the same setup).
Pressing the eMMC in position on the Rock64, booting went without a hitch. ..
BTW, you immediately notice that boot time is reduced...
PS I used gparted to fill the 64GB module...
I plan to buy a Rock64 for using it with ubuntu on an eMMC module. I wonder what do i need to flash Ubuntu on the eMMC:
- an eMMC-USB adapter found here  https://www.pine64.org/?product=usb-adap...mmc-module and then use PINE64 installer and then plug the eMMC module on the Rock64
or
-  an eMMC-µSD + USB-µSD-reader (like the one indicated by pytheas)  and then use PINE64 installer and then plug the eMMC module on the Rock64
or something else? no needs to transfer ubuntu fro µSD to eMMC as i was able to read it sometimes?
regards
The adapter is very useful at the moment because allows you to flash any OS image you want. However, ayufan is working on making it easier to install his images to eMMC without the adapter.
Regardless, I feel that everyone should get it just to sparethemselves the trouble of flashing eMMC the hard way.
Question Compatible eMMC modules and benchmarks danboid 7 26,482 03-09-2023, 08:14 AM
Last Post: arvendui
  DAC (ES9023) addon card on other SBCs like rpi? AlexS 1 6,209 08-28-2021, 04:53 AM
Last Post: CounterPillow
Information Rock64 RTL8188EU Wifi Adapter from Pine Store Tested Well MarkHaysHarris777 7 17,811 05-13-2020, 06:00 PM
Last Post: Leon Rembowski
Question Have eMMC adapter - but can't seem to fix eMMC card SirRyanTheGeek 3 11,935 05-04-2019, 04:19 AM
Last Post: burito111
  Will Gert's VGA666 adapter work with the Rock64? Other display options? pcosm 0 3,328 05-03-2019, 01:32 AM
Last Post: pcosm
  emmc module help default_user8 1 5,192 04-05-2019, 07:19 PM
Last Post: SirRyanTheGeek
  Does the Pine usb to sata adapter work with hd-parm? FabrizioMaurizio 0 3,323 02-06-2019, 11:37 AM
Last Post: FabrizioMaurizio
  ROCK64 STEREO AUDIO DAC ADD-ON BOARD and USB serial adapter for Pine64 jovval 2 6,705 12-01-2018, 03:53 AM
Last Post: jovval
  Dead eMMC? machina 8 16,209 11-21-2018, 05:05 AM
Last Post: machina
  FORSEE eMMC is reliable? ramprasad 3 8,976 11-12-2018, 03:34 PM
Last Post: Tortax
