Rock64 as a firewall - usb3 gigE adopters
I am considering setting up my rock 64 as a firewall using IPFire which will require another Ethernet port. There are many usb3 to Ethernet adapters and I am not sure if they are compatible. Here are a couple of options:
https://www.amazon.com/Anker-Portable-Et...t+ethernet
https://www.amazon.com/AmazonBasics-1000...t+ethernet
This brings me to my questions.
1. Has anyone successfully tested using a usb3 gigE adapter on Ayufun's latest Debian release?
2. If yes, is there a specific version that is needed for compatibility purposes?
3. Do we think that either of the ones linked above will work? If not is there an alternate that you would suggest?
Thank you
(10-08-2017, 08:29 AM)jl_678 Wrote: Hi,
Thank you
IP fire is a distro with no support for Rockchip or the RK3328 or Rock64.
The anker is a realtek r8152
Amazon basic is a Asix AX88179/178A
Never heard of Asix but realtek are real common.
But unless you are going to go full developer mode and create your own image for IPFire with all the work Ayufan has done then maybe think about that the Anker might not get used.
Thank you
I noticed this audio "hat" in the pine64 store:  https://www.pine64.org/?product=rock64-s...d-on-board
which has an additional 10/100 ethernet port...  might work for your firewall purposes.
Also, if the IPFire distro doesn't support ROCK64, you could just install one of the minimal distros and use IPtables.  ('ufw' package makes managing rules easier than editing by hand)
  irradium (based on crux linux) Rock64 riscv64, aarch64 mara 12 17,755 03-07-2026, 11:04 AM
  Rock64 v3 Tx/RX and GPIO connections for 3dprinter MinimumJargon 2 704 01-28-2026, 04:04 AM
Last Post: alicesphere
  Rock64 - not booting after Armbian update helpmerock 7 5,321 01-24-2026, 04:44 PM
Last Post: ff255
  Xen hypervisor on Rock64 tumbleweed 6 11,206 11-03-2025, 09:25 AM
Last Post: darkfader
  can rock64 4gb ram run entirely on free software? heocb 1 2,883 01-07-2025, 05:47 AM
  Upgrading ancient Rock64 timxjr1300 1 3,066 11-26-2024, 09:47 AM
Last Post: dmitrymyadzelets
  arch rock64 does not boot nemnob 1 4,191 09-20-2024, 11:18 AM
Last Post: AwU2HBg
  DietPi OS for ROCK64 MichaIng 42 82,682 09-01-2024, 06:43 AM
Last Post: RaymondDay
Smile First Lakka image for Rock64! Luke 47 107,546 09-01-2024, 06:05 AM
  Rock64 v2 - did not work song / audio sqw200zu 2 5,589 03-14-2024, 03:09 AM
