RTL8188EU Wifi Dongle
https://www.pine64.org/?product=usb-wifi...for-rock64
anyone have success with the dongle listed above?
Am I missing any step(s)?
running ubuntu 16.04 with linux-rock64 v 0.5.13
(09-24-2017, 09:14 PM)experinominis Wrote: https://www.pine64.org/?product=usb-wifi...for-rock64
https://forum.pine64.org/showthread.php?tid=5079
(09-25-2017, 12:52 AM)tllim Wrote: https://forum.pine64.org/showthread.php?tid=5079
this link speaks only to having it work with Xenial Mate. Nothing for Xenial Minimal. Not sure what would be different about them;
> nmcli c
only shows wired connection on eth0
that link is no help.
I figured it out, though.  If anyone else comes across this thread:
First thing is to test if your usb dongle is a dud.  I ordered two, thankfully!!   One of them looks like its DOA.  The other one:
If you're running Xenial Minimal, you can use the command line to connect to your WiFi network.   I have WPA2 network security so I didn't test whether this works for WEP security.
1. enable network manager
> sudo service NetworkManager start
2. make sure your device is found
> lsusb
you should see a RealTek Semiconductor Wifi...
3. find out the deviceId.  its not wlan0 like some other forums would have you believe.
> nmcli d
mine was listed as 'wlx0013ef800a43'
4.  Connect!
> nmcli d wifi connect <WiFiSSID> password <WiFiPASSWORD>
Hit Enter.
It said it successfully created a connection for wlx0013ef800a43
5. Test connection
> ifconfig
now shows that I've picked up a DHCP IP addr from my wireless router.
> ping google.com
sends results Smile
Update:
this usb WiFi dongle worked out-of-the-box:
https://www.amazon.com/gp/product/B008IF...UTF8&psc=1
this usb WiFi dongle didn't:
https://www.amazon.com/gp/product/B00JDV...UTF8&psc=1
(09-29-2017, 04:24 PM)experinominis Wrote: Update:
Do I need to update the firmware on the board before I can use the wifi adapters? Or was my android image from the GUI just not supporting wifi at the time?
  get wifi mt7601u mediatek usb dongle to work Johannes 0 6,563 11-17-2020, 09:48 AM
Last Post: Johannes
Information Rock64 RTL8188EU Wifi Adapter from Pine Store Tested Well MarkHaysHarris777 7 17,472 05-13-2020, 06:00 PM
Last Post: Leon Rembowski
  RTL8192EU WIFI elik745i 12 37,092 05-13-2020, 05:03 PM
  low speed wifi pas059 4 9,295 05-13-2019, 12:09 PM
Last Post: pas059
  Using ESP32 as WiFi and Bluetooth Module shripal17 2 7,023 03-08-2019, 02:44 AM
Last Post: shripal17
  50 kb with RTL8188eu WIFI adapter Juice4 2 6,374 11-09-2018, 12:56 PM
Last Post: Juice4
  WIFI driver compilation wsk 1 4,860 11-01-2018, 12:21 AM
Last Post: wsk
  Wifi; how to? scalextrix 12 27,753 05-30-2018, 12:20 AM
Last Post: scalextrix
  Very disappointed with ROCK64 USB WIFI 802.11B/G/N Danielsan 0 3,624 04-23-2018, 09:51 AM
Last Post: Danielsan
  None of my Wifi modules work NicoD 7 15,042 04-05-2018, 02:53 PM
