Firefox crash
hi friends.
Firefox crashes when downloading files with mega .Debian mate help me.thanks
Have you checked the log ? does it give you an indication of what may be the issue ?
Does it happen on Midori or Chromium ?
I am having the similar issue. All browsers are shutting down before, or when finished loading, except for Midori.
Nothing showing up in the logs.
(08-16-2017, 08:48 PM)KNERD Wrote: I am having the similar issue. All browsers are shutting down before, or when finished loading, except for Midori.
Which image specifically ? - uname -a
It is returning:
Quote:Linux pine64 3.10.105-0-pine64-longsleep #3 SMP PREEMPT Sat Mar 11 16:05:53 CET 2017 aarch64 GNU/Linu
x
It is returning:
x
Ah yes. Switch over to one of these images.
It is returning:
x
I did get the one I am using from the wiki for suggested images.
Does it matter which one? I know there are ones which state Pine64, which I have, but they are minimal installations. In my experience Minimal means just the core OS with nothing else fancy installing. Can I use one of those nice PineBook images on a Pine64?
It is returning:
x
You can't use the Pinebook image. Just get the minimal image and use the script in /usr/local/sbin to install a desktop ... You'll be given a choice between mate or i3. You can obviously install XFCE to manually... or something else for that matter.
I installed the simple-image-pine64-0.6.2.
After installing Mate desktop I see a "Pinebook" logo.
Browser functioning. Thanks
Users browsing this thread: 7 Guest(s)
