Hi I'm using Android 6.0 official image in Pinebook, all works fine at this moment but I don't know why the sound goes away after suspend and if could be possible to fix it.
No sound after suspend
(07-28-2017, 10:13 AM)kurai021 Wrote: Hi I'm using Android 6.0 official image in Pinebook, all works fine at this moment but I don't know why the sound goes away after suspend and if could be possible to fix it. This isn't exactly a solution to your problem - but have you considered using ayufan's A7.1 instead ? It is also rooted, has split screen, better performance, and is continually developed. You can also flash it to eMMC following my instructions. [edit] thread moving thread to Pinebook -> Android |
