No sound after suspend
Sad
Hi I'm using Android 6.0 official image in Pinebook, all works fine at this moment but I don't know why the sound goes away after suspend and if could be possible to fix it. Sad
(07-28-2017, 10:13 AM)kurai021 Wrote: Hi I'm using Android 6.0 official image in Pinebook, all works fine at this moment but I don't know why the sound goes away after suspend and if could be possible to fix it. Sad
This isn't exactly a solution to your problem - but have you considered using ayufan's  A7.1 instead ? It is also rooted, has split screen, better performance, and is continually developed. You can also flash it to eMMC following my instructions.
[edit] thread moving thread to Pinebook -> Android
