dead keys days after warranty expires
Hello everyone!
Loving my pinebook so far, q4OS runs beautifully and the hardware is surprisingly nice for the price point!
Unfortunately the keyboard now has 2 dead keys (a and s) days after my warranty has expired.
Is it worth breaking open the pinebook to see if I can reseat the rubber dome or clean the connection or am I SOL?
Thanks.
EDIT: the keyboard actually has 3 dead keys, Caps, A, and S.
There was no trauma to the unit as far as I am aware.
if you have not already, take a look at the photos in the thread, "a full teardown"
https://forum.pine64.org/showthread.php?tid=4523
(05-14-2017, 11:57 AM)sgiavaras Wrote: <snip>
<snip>
Interesting.
... did you spill anything into it ?   knowing, or unknowing ?  ( you won't know except to open it )
I would open it;  remove power (unplug the battery) and then reseat all of the connectors;  please deshock yourself (ground yourself first).
Usually when buble domes stick many more keys die ...  do a full check of the keyboard;  probably more than those keys are out ( column or row )?   (not keyboard row, eletrical row-- scanning row)
tab Q Z space   etc
I suspect that if you reseat all connectors it will work again.
Thanks for the helpful advice!
When I have some free time this week I'll be opening it up. I suspect that reseating all the connections will solve my problem.
Will update when I do!
  Dead Pinebook - fix it or spare parts? oloturia 2 8,228 03-19-2023, 03:38 PM
Last Post: oloturia
  Pinebook without stuck or dead pixel Timeo 6 15,490 06-01-2020, 04:45 AM
Last Post: pfeerick
  Dead original pinebook calcmandan 1 4,706 11-30-2019, 07:10 AM
Last Post: 33YN2
  Alsamixer - can't select with keys jschall 2 6,037 11-18-2018, 03:49 PM
Last Post: jschall
  A seemingly dead Pinebook. frank-zappa 6 12,284 04-17-2018, 12:11 AM
Last Post: dkryder
Question Survey - Dead Pixels MiningBrutus 30 48,714 10-28-2017, 03:36 AM
Last Post: erchache2000
