Q: dont know what tyo do?
hi all. I purchased the 89 backer pkg. as well as 1 of every item.  i am not even sure what the possibilities are with this but im hoping i can get some honest help here.
$89 REWARD
The PINE A64+ Box w/ Touch Screen You will get the PINE A64+ 1GB unit along with 64GB MicroSD Pre-Loaded with Android 5.1 OS, 802.11N Wifi + Bluetooth 4.0, PINE64 Power Supply, 7" LCD touchscreen panel, the PINE64 Enclosure. 2GB upgrade available for $10 later. (Light Assembly Required)
Pledge Questions
What kind of power supply do you need?
USA 5V Power Supply
Would you like to upgrade to the 2GB model for an extra $10?
Yes, upgrade to 2GB!
What are you planning on building / doing with your PINE64?
i truly have no idea
Update Your Answers
Add-ons
5 Way 12C Cable
Qty: 1 x $1.25
4 Way 12C Cable
Qty: 1 x $1.25
5-Way to 4-Way I2C Cable
Qty: 1 x $1.25
PINE64 Z-Wave Module (US version)
Qty: 1 x $29.99
USB Keyboard HUB.
Qty: 1 x $10.99
PINE64 Ambient Light Sensor
Qty: 1 x $9.24
PINE64 Air Mouse with Keyboard
Qty: 1 x $20.24
5MP Camera Module
Qty: 1 x $13.24
8000mAH 3.7V Lithium Polymer Battery *USA ONLY
Qty: 1 x $20.49
Update Your Cart
What Happens Next?
(02-24-2016, 02:49 PM)1happyinfidel Wrote: hi all. I purchased the 89 backer pkg. as well as 1 of every item.  i am not even sure what the possibilities are with this but im hoping i can get some honest help here.
$89 REWARD
Pledge Questions
USA 5V Power Supply
Update Your Answers
Add-ons
5 Way 12C Cable
Qty: 1 x $1.25
4 Way 12C Cable
Qty: 1 x $1.25
Qty: 1 x $1.25
Qty: 1 x $29.99
USB Keyboard HUB.
Qty: 1 x $10.99
Qty: 1 x $9.24
Qty: 1 x $20.24
5MP Camera Module
Qty: 1 x $13.24
Qty: 1 x $20.49
Update Your Cart
What Happens Next?
I am not sure what your question is.  Are you asking which of these you should order or what you should build or something else?  Truthfully, if you are really uncertain then you might be better served buying a subset of items initially so you can learn the basics and then decide what you want to add-on later once you decide on your desired project.
Don't get me wrong, ordering alot of stuff can be valuable, but if you don't have a goal in mind, you are at risk of ordering stuff that you might never use which is not idea either...
$89 REWARD
Pledge Questions
USA 5V Power Supply
Update Your Answers
Add-ons
5 Way 12C Cable
Qty: 1 x $1.25
4 Way 12C Cable
Qty: 1 x $1.25
Qty: 1 x $1.25
Qty: 1 x $29.99
USB Keyboard HUB.
Qty: 1 x $10.99
Qty: 1 x $9.24
Qty: 1 x $20.24
5MP Camera Module
Qty: 1 x $13.24
Qty: 1 x $20.49
Update Your Cart
What Happens Next?
i ordered all above as it wasn't in my mind very $$$ but I'm not sure what others are doing I guess I'm looking for inspiration..
There's a section on Project Ideas in the General section of this forum. Maybe you'll find some inspiration there.
Sent from my HTC One M9 using Tapatalk
Users browsing this thread:
