Bad lcd?
Just wondering if it's possible I have a bad lcd? Ive followed the instructions https://www.youtube.com/watch?v=DTCIiChXfSQ to install the lcd but I only get a blank screen. Everything looks good, the cables are tight, can send a pic if asked. Don't know what's wrong. Using the Android OS as it supports the lcd, and I get a boot when I connect the pineA64 to my TV. Bought a new power plug in case that was it and right now running out of ideas........ Was very happy to get the OS to finally boot and am getting anxious to start to use the Pine...
You need to edit a file to turn the LCD on to make it work. Do some searching and you'l find a bunch of posts about it. File is in Root name UNEV
(03-11-2017, 12:15 AM)simplexdan Wrote: You need to edit a file to turn the LCD on to make it work. Do some searching and you'l find a bunch of posts about it. File is in Root name UNEV
Awesome! Thanks!  This device is a totally new experience for me. It's good to jump outside your comfort zone, right??
