SPI python ?
Sad
How i can access SPI pin (pi2bus or euler) with python spidev?
i look in the raspberry, the SPI port must be enable before using through raspi-config. How about pine64?
Thank's Smile
Use this Python library : https://github.com/swkim01/RPi.GPIO-PineA64
Here some loopback testing code :
#!/usr/bin/python import RPi.SPI as spi data = [0xDE,0xAD,0xBE,0xEF,0xBA,0xAD,0xF0,0x0D] spi.open("/dev/spidev0.0") spi.write(data) data = spi.xfer(data, len(data)) spi.close() print data
(01-06-2017, 09:15 AM)martinayotte Wrote: Use this Python library : https://github.com/swkim01/RPi.GPIO-PineA64
Thanks Martinayotte,
What the spi.xfer?
I look 2 pins SPI (pi2bus and euler),
which the pin i can call /dev/spidev0.0 and /dev/spidev0.1?
On raspi tutorial, we can look spidev0.0 in /dev but in pine not found.
Sent from my Mi-4c using Tapatalk
spi.xfer() is transmitting and receiving at the same time, full-duplex transfer.
If you don't see /dev/spi0.0 on your board, it is probably that you don't use an image using longsleep's kernel, because SPIs have been added in the DT of longsleep several months ago.
I feel that this image is pretty old. Which version is show when doing "uname -a"
If you don't mind switch to Ubuntu, here is on image built in December :
http://files.pine64.org/os/ubuntu/xubunt...8GB.img.gz
or even better, one from Armbian :
https://img.armbian.com/pine64/Ubuntu_xe...desktop.7z
Thanks Martinayotte,, i will try it
Martinayotte, i was tried armbian..
But SPI port not appear in /dev/
what the configuration for appear spidev0.0/spidev0.1?
Mmmh I was looking at...
https://github.com/longsleep/build-pine6....dts#L1849
https://github.com/longsleep/build-pine6....dts#L1865
Maybe the SPI blocks are disabled by default to have the pins as GPIO?
(01-17-2017, 03:40 PM)xalius Wrote: Mmmh I was looking at...
Can i enabling, how?
