09-02-2016, 10:59 AM
Does anybody tried to create cluster of Pine64s on Mesos? Is it possible?
Mesos?
09-07-2016, 06:35 PM
12-30-2016, 12:54 PM
(This post was last modified: 12-30-2016, 12:59 PM by HazMatSuit.)
I bought 3 Pine64 boards specifically to try that out. I have 2 of them up and running on Ubuntu 16.04 per longsleep's build. THat's the good news.
The bad news is that I cannot get mesos building. I keep gettign errors in building the 3rdparty google logging code. UNAME_MACHINE = aarch64 UNAME_RELEASE = 3.10.102-0-pine64-longsleep UNAME_SYSTEM = Linux UNAME_VERSION = #7 SMP PREEMPT Fri Jun 17 21:30:48 CEST 2016 configure: error: cannot guess build type; you must specify one Makefile:1147: recipe for target 'glog-0.3.3-build-stamp' failed make[3]: *** [glog-0.3.3-build-stamp] Error 1 make[3]: Leaving directory '/home/debian/mesos/build/3rdparty' Makefile:832: recipe for target 'all-recursive' failed make[2]: *** [all-recursive] Error 1 make[2]: Leaving directory '/home/debian/mesos/build/3rdparty' Makefile:647: recipe for target 'all' failed make[1]: *** [all] Error 2 make[1]: Leaving directory '/home/debian/mesos/build/3rdparty' Makefile:762: recipe for target 'all-recursive' failed make: *** [all-recursive] Error 1 Any ideas? I am wondering if I cannot build glog on aarch64 or if make doesn't know the overall target. I bought 3 Pine64 boards specifically to try that out. I have 2 of them up and running on Ubuntu 16.04 per longsleep's build. THat's the good news. The bad news is that I cannot get mesos building. I keep gettign errors in building the 3rdparty google logging code. UNAME_MACHINE = aarch64 UNAME_RELEASE = 3.10.102-0-pine64-longsleep UNAME_SYSTEM = Linux UNAME_VERSION = #7 SMP PREEMPT Fri Jun 17 21:30:48 CEST 2016 configure: error: cannot guess build type; you must specify one Makefile:1147: recipe for target 'glog-0.3.3-build-stamp' failed make[3]: *** [glog-0.3.3-build-stamp] Error 1 make[3]: Leaving directory '/home/debian/mesos/build/3rdparty' Makefile:832: recipe for target 'all-recursive' failed make[2]: *** [all-recursive] Error 1 make[2]: Leaving directory '/home/debian/mesos/build/3rdparty' Makefile:647: recipe for target 'all' failed make[1]: *** [all] Error 2 make[1]: Leaving directory '/home/debian/mesos/build/3rdparty' Makefile:762: recipe for target 'all-recursive' failed make: *** [all-recursive] Error 1 Any ideas? I am wondering if I cannot build glog on aarch64 or if make doesn't know the overall target.
01-02-2017, 04:42 PM
I doubt it will be smooth at the moment.
https://issues.apache.org/jira/browse/ME...ext%20~%20"arm64" lists few open bugs. Even updating dependencies and fixing some minor issues, the compiled binaries segfault right now. the glog issue might be some issue with go language / compiler. Maybe you could try doing this again with Debian sid/unstable version instead?
01-04-2017, 08:50 AM
(This post was last modified: 01-04-2017, 08:50 AM by HazMatSuit.)
(01-02-2017, 04:42 PM)baryluk Wrote: I doubt it will be smooth at the moment. Thanks. I'll give it a try and let you know.
04-10-2018, 10:12 AM
(09-02-2016, 10:59 AM)kermitas Wrote: Does anybody tried to create cluster of Pine64s on Mesos? Is it possible? sure, it been done for awhile, assume you inderstand how docker works: https://hub.docker.com/r/mdef/mesos-arm64/ you need to pull image and than run container. mesos-agent inside image compiled for arm64. |
