Problems with remote printers with pine64 (SOLVED)
Hi guys,
This is my very first post. Last Saturday I changed my rpi2 for a pine64 just to do the same functions that rpi2 did. I migrated my webpages, network drivers and two printers. I copied smb.conf and cupds.conf to pine64 (both with boards have debian installed) but it didn't work. After removing and reinstalling cups several times just to see if all worked, pine64 had an error during boot (sorry, I don't remember the exact error), so I let for a few days.
Yesterday, I tried with ubuntu 16.04 loongsleep but I had the same results. I can print from local, but I can't print from any remote machine and the config is the same I had in rpi2.
Could anyone give me some clue? I'll update later this post with cupsd.conf and smb.conf.
Thanks in advance.
Edit:
I've added this to cupds.conf:
security = user
So now it's working! Thanks for your support Smile
yea, I think we need to see the configs to be able to help. I recently set up cups and smb on a pine and it wasn't exactly smooth sailing (the fault could be with me and not the pine). I got SMB and my AIO printer working eventually, but still can't get the scanner up an running...
Here you have the two files.
cupds.conf
LogLevel warn MaxLogSize 1m # Allow remote access Port 631 Listen /var/run/cups/cups.sock # Share local printers on the local network. Browsing On BrowseLocalProtocols dnssd DefaultAuthType Basic WebInterface Yes <Location />  # Allow shared printing...  Order allow,deny  Allow all </Location> <Location /admin> </Location> <Location /admin/conf>  AuthType Default  Require user @SYSTEM </Location> <Policy default>  JobPrivateAccess default  JobPrivateValues default  SubscriptionPrivateAccess default  SubscriptionPrivateValues default  <Limit Create-Job Print-Job Print-URI Validate-Job>    Order deny,allow  </Limit>  <Limit Send-Document Send-URI Hold-Job Release-Job Restart-Job Purge-Jobs Set-Job-Attributes Create-Job-Subscription Renew-Subscription Cancel-Subscription Get-Notifications Reprocess-Job Cancel-Current-Job Suspend-Current-Job Resume-Job Cancel-My-Jobs Close-Job CUPS-Move-Job CUPS-Get-Document>    Require user @OWNER @SYSTEM    Order deny,allow  </Limit>  <Limit CUPS-Add-Modify-Printer CUPS-Delete-Printer CUPS-Add-Modify-Class CUPS-Delete-Class CUPS-Set-Default CUPS-Get-Devices>    AuthType Default    Require user @SYSTEM    Order deny,allow  </Limit>  <Limit Pause-Printer Resume-Printer Enable-Printer Disable-Printer Pause-Printer-After-Current-Job Hold-New-Jobs Release-Held-New-Jobs Deactivate-Printer Activate-Printer Restart-Printer Shutdown-Printer Startup-Printer Promote-Job Schedule-Job-After Cancel-Jobs CUPS-Accept-Jobs CUPS-Reject-Jobs>    AuthType Default    Require user @SYSTEM    Order deny,allow  </Limit>  <Limit Cancel-Job CUPS-Authenticate-Job>    Require user @OWNER @SYSTEM    Order deny,allow  </Limit>  <Limit All>    Order deny,allow  </Limit> </Policy> <Policy authenticated>  JobPrivateAccess default  JobPrivateValues default  SubscriptionPrivateAccess default  SubscriptionPrivateValues default  <Limit Create-Job Print-Job Print-URI Validate-Job>    AuthType Default    Order deny,allow  </Limit>  <Limit Send-Document Send-URI Hold-Job Release-Job Restart-Job Purge-Jobs Set-Job-Attributes Create-Job-Subscription Renew-Subscription Cancel-Subscription Get-Notifications Reprocess-Job Cancel-Current-Job Suspend-Current-Job Resume-Job Cancel-My-Jobs Close-Job CUPS-Move-Job CUPS-Get-Document>    AuthType Default    Require user @OWNER @SYSTEM    Order deny,allow  </Limit>  <Limit CUPS-Add-Modify-Printer CUPS-Delete-Printer CUPS-Add-Modify-Class CUPS-Delete-Class CUPS-Set-Default>    AuthType Default    Require user @SYSTEM    Order deny,allow  </Limit>  <Limit Pause-Printer Resume-Printer Enable-Printer Disable-Printer Pause-Printer-After-Current-Job Hold-New-Jobs Release-Held-New-Jobs Deactivate-Printer Activate-Printer Restart-Printer Shutdown-Printer Startup-Printer Promote-Job Schedule-Job-After Cancel-Jobs CUPS-Accept-Jobs CUPS-Reject-Jobs>    AuthType Default    Require user @SYSTEM    Order deny,allow  </Limit>  <Limit Cancel-Job CUPS-Authenticate-Job>    AuthType Default    Require user @OWNER @SYSTEM    Order deny,allow  </Limit>  <Limit All>    Order deny,allow  </Limit> </Policy> MaxClients 10
smb.conf
# # Sample configuration file for the Samba suite for Debian GNU/Linux. # # # This is the main Samba configuration file. You should read the # smb.conf(5) manual page in order to understand the options listed # here. Samba has a huge number of configurable options most of which # are not shown in this example # # Some options that are often worth tuning have been included as # commented-out examples in this file. #  - When such options are commented with ";", the proposed setting #    differs from the default Samba behaviour #  - When commented with "#", the proposed setting is the default #    behaviour of Samba but the option is considered important #    enough to be mentioned here # # NOTE: Whenever you modify this file you should run the command # "testparm" to check that you have not made any basic syntactic # errors. #======================= Global Settings ======================= [global] ## Browsing/Identification ### # Change this to the workgroup/NT-domain name your Samba server will part of   workgroup = WORKGROUP # Windows Internet Name Serving Support Section: # WINS Support - Tells the NMBD component of Samba to enable its WINS Server #   wins support = no # WINS Server - Tells the NMBD components of Samba to be a WINS Client # Note: Samba can be either a WINS Server, or a WINS Client, but NOT both ;   wins server = w.x.y.z # This will prevent nmbd to search for NetBIOS names through DNS.   dns proxy = no #### Networking #### # The specific set of interfaces / networks to bind to # This can be either the interface name or an IP address/netmask; # interface names are normally preferred ;   interfaces = 127.0.0.0/8 eth0 # Only bind to the named interfaces and/or networks; you must use the # 'interfaces' option above to use this. # It is recommended that you enable this feature if your Samba machine is # not protected by a firewall or is a firewall itself.  However, this # option cannot handle dynamic or non-broadcast interfaces correctly. ;   bind interfaces only = yes #### Debugging/Accounting #### # This tells Samba to use a separate log file for each machine # that connects   log file = /var/log/samba/log.%m # Cap the size of the individual log files (in KiB).   max log size = 1000 # If you want Samba to only log through syslog then set the following # parameter to 'yes'. #   syslog only = no # We want Samba to log a minimum amount of information to syslog. Everything # should go to /var/log/samba/log.{smbd,nmbd} instead. If you want to log # through syslog you should set the following parameter to something higher.   syslog = 0 # Do something sensible when Samba crashes: mail the admin a backtrace   panic action = /usr/share/samba/panic-action %d ####### Authentication ####### # Server role. Defines in which mode Samba will operate. Possible # values are "standalone server", "member server", "classic primary # domain controller", "classic backup domain controller", "active # directory domain controller". # # Most people will want "standalone sever" or "member server". # Running as "active directory domain controller" will require first # running "samba-tool domain provision" to wipe databases and create a # new domain.   server role = standalone server # If you are using encrypted passwords, Samba will need to know what # password database type you are using.     passdb backend = tdbsam   obey pam restrictions = yes # This boolean parameter controls whether Samba attempts to sync the Unix # password with the SMB password when the encrypted SMB password in the # passdb is changed.   unix password sync = yes # For Unix password sync to work on a Debian GNU/Linux system, the following # parameters must be set (thanks to Ian Kahan <<kahan@informatik.tu-muenchen.de> for # sending the correct chat script for the passwd program in Debian Sarge).   passwd program = /usr/bin/passwd %u   passwd chat = *Enter\snew\s*\spassword:* %n\n *Retype\snew\s*\spassword:* %n\n *password\supdated\ssuccessfully* . # This boolean controls whether PAM will be used for password changes # when requested by an SMB client instead of the program listed in # 'passwd program'. The default is 'no'.   pam password change = yes # This option controls how unsuccessful authentication attempts are mapped # to anonymous connections   map to guest = bad user ########## Domains ########### # # The following settings only takes effect if 'server role = primary # classic domain controller', 'server role = backup domain controller' # or 'domain logons' is set # # It specifies the location of the user's # profile directory from the client point of view) The following # required a [profiles] share to be setup on the samba server (see # below) ;   logon path = \\%N\profiles\%U # Another common choice is storing the profile in the user's home directory # (this is Samba's default) #   logon path = \\%N\%U\profile # The following setting only takes effect if 'domain logons' is set # It specifies the location of a user's home directory (from the client # point of view) ;   logon drive = H: #   logon home = \\%N\%U # The following setting only takes effect if 'domain logons' is set # It specifies the script to run during logon. The script must be stored # in the [netlogon] share # NOTE: Must be store in 'DOS' file format convention ;   logon script = logon.cmd # This allows Unix users to be created on the domain controller via the SAMR # RPC pipe.  The example command creates a user account with a disabled Unix # password; please adapt to your needs ; add user script = /usr/sbin/adduser --quiet --disabled-password --gecos "" %u # This allows machine accounts to be created on the domain controller via the # SAMR RPC pipe.   # The following assumes a "machines" group exists on the system ; add machine script  = /usr/sbin/useradd -g machines -c "%u machine account" -d /var/lib/samba -s /bin/false %u # This allows Unix groups to be created on the domain controller via the SAMR # RPC pipe.   ; add group script = /usr/sbin/addgroup --force-badname %g ############ Misc ############ # Using the following line enables you to customise your configuration # on a per machine basis. The %m gets replaced with the netbios name # of the machine that is connecting ;   include = /home/samba/etc/smb.conf.%m # Some defaults for winbind (make sure you're not using the ranges # for something else.) ;   idmap uid = 10000-20000 ;   idmap gid = 10000-20000 ;   template shell = /bin/bash # Setup usershare options to enable non-root users to share folders # with the net usershare command. # Maximum number of usershare. 0 (default) means that usershare is disabled. ;   usershare max shares = 100 # Allow users who've been granted usershare privileges to create # public shares, not just authenticated ones   usershare allow guests = yes #======================= Share Definitions ======================= [homes]   comment = Home Directories   browseable = no # By default, the home directories are exported read-only. Change the # next parameter to 'no' if you want to be able to write to them.   read only = yes # File creation mask is set to 0700 for security reasons. If you want to # create files with group=rw permissions, set next parameter to 0775.   create mask = 0700 # Directory creation mask is set to 0700 for security reasons. If you want to # create dirs. with group=rw permissions, set next parameter to 0775.   directory mask = 0700 # By default, \\server\username shares can be connected to by anyone # with access to the samba server. # The following parameter makes sure that only "username" can connect # to \\server\username # This might need tweaking when using external authentication schemes   valid users = %S # Un-comment the following and create the netlogon directory for Domain Logons # (you need to configure Samba to act as a domain controller too.) ;[netlogon] ;   comment = Network Logon Service ;   path = /home/samba/netlogon ;   guest ok = yes ;   read only = yes # Un-comment the following and create the profiles directory to store # users profiles (see the "logon path" option above) # (you need to configure Samba to act as a domain controller too.) # The path below should be writable by all users so that their # profile directory may be created the first time they log on ;[profiles] ;   comment = Users profiles ;   path = /home/samba/profiles ;   guest ok = no ;   browseable = no ;   create mask = 0600 ;   directory mask = 0700 [printers]   comment = All Printers   browseable = no   path = /var/spool/samba   printable = yes   guest ok = no   read only = yes   create mask = 0700 # Windows clients look for this share name as a source of downloadable # printer drivers [print$]   comment = Printer Drivers   path = /var/lib/samba/printers   browseable = yes   read only = yes   guest ok = no # Uncomment to allow remote administration of Windows print drivers. # You may need to replace 'lpadmin' with the name of the group your # admin users are members of. # Please note that you also need to set appropriate Unix permissions # to the drivers directory for these users to have write rights in it ;   write list = root, @lpadmin
Thanks in advance Smile
  Programming languages support under PINE64 baryluk 6 20,689 09-23-2020, 11:46 PM
Last Post: Phillip Bell
  Manjaro arm on pine64+ roel 2 10,664 10-19-2019, 05:13 AM
Last Post: roel
  Volumio for PINE64 Released mikelangeloz 11 39,184 03-22-2019, 09:25 AM
Last Post: llungster
  I2S Audio patches for Pine64+ uploaded to GitHub ramstadt 1 6,668 01-19-2019, 11:31 AM
Last Post: ramstadt
  Pine64: Minimal SDL config Max11 3 10,128 01-04-2019, 03:47 PM
Last Post: Max11
  Fedora 27 on Pine64 gregjo 18 57,211 01-02-2019, 10:42 PM
Last Post: heatfanjohn
  Official build procedure of ayufan pine64 r.tanaka 0 4,981 08-21-2018, 10:54 PM
Last Post: r.tanaka
  DKMS on kernel 3.10.107-pine64 obrienmd 5 14,600 06-21-2018, 05:45 PM
Last Post: evilbunny
  Gentoo for pine64 - longsleep kernel incoherent 0 5,686 12-09-2017, 08:14 AM
Last Post: incoherent
  Fedora Running On Pine64! cztian 26 60,113 10-26-2017, 05:51 PM
Last Post: gregjo
Users browsing this thread:
