Since the pine64's HDMI port doesn't support my monitor's screen resolution, once MackPi figured out how to enable the LCD screen in Linux, I went ahead and ordered 3 of the touchscreens. Sure, they're a bit small, but you can't beat the price.
For my mini-desktop machine, I needed something to hold the screen up at the correct viewing angle. I started with a little plastic ipod holder which worked a little, but kept getting knocked down. Next I worked at making something out of cardboard. That would have worked, had I been able to locate some zip ties to attach the screen. But while looking through my garage for the zip ties, I found a box of craft sticks (popsicle sticks) and my mind started working.
I ended up making a mini-monitor stand out of the popsicle sticks, some hot glue, and rubber bands. It actually works really well! Here are some pictures of it:
That project ended up being pretty fun and easy, so now I'm thinking of making an entire case out of the sticks. I'm imagining making something that folds into a box when not being used, but opens up into something like a mini-netbook. If I can make it work, I'll be looking for a small wooden keyboard and mouse to go with it.
Chris
Chris
