Netatalk on Debian
(05-01-2016, 03:11 PM)baryluk Wrote: I rebooted the pine and everything is still fine.
I cannot get installed this package: libkrb5-dev
Some packages could not be installed. This may mean that you have
requested an impossible situation or if you are using the unstable
distribution that some required packages have not yet been created
or been moved out of Incoming.
The following information may help to resolve the situation:
The following packages have unmet dependencies:
 libkrb5-dev : Depends: krb5-multidev (= 1.12.1+dfsg-19+deb8u2) but it is not going to be installed
E: Unable to correct problems, you have held broken packages.
How can I correct it?
Thank you!
Wojciech
  Arch, Debian or other for Pinebook? cootcraig 3 11,661 05-01-2019, 09:11 AM
Last Post: cootcraig
  Pine64 will be supported by HypriotOS (a Debian Jessie based OS for running Docker) Quintus23M 9 26,076 02-03-2017, 05:50 AM
Last Post: pfeerick
  How to make multicast working on ubuntu and debian brengthdom 3 10,683 09-18-2016, 02:05 PM
Last Post: brengthdom
  SSH for noobs on Debian robertnew 12 30,758 05-07-2016, 08:02 AM
Last Post: Leoncito81
Lightbulb Debian (Raspbian-like) Pander 15 34,428 04-09-2016, 08:40 PM
Last Post: lenny.raposo-pine64.pro
  Minimal 64bit ARM RootFS for Debian and Ubuntu umiddelb 46 108,329 03-06-2016, 10:28 AM
Last Post: umiddelb
  1st Debian image and further information umiddelb 13 32,696 03-04-2016, 02:08 AM
Last Post: umiddelb
