Install PlayBox Enclosure - pics
http://imgur.com/a/FEx8T
No official pics here, just what I was able to work out for myself. I hope some of you find this helpful (or offer improved ways of doing it).
i found i had to chop a chunk out of the battery spacer in order to remove the micro sd card...
(used a dremel rotary tool)
  Install OpenWrt on A64+ without serial? JuniperFury 5 13,941 12-25-2021, 10:31 AM
Last Post: guenther
  Is possible to install Home Assistant on pine64 2gb? polv89 1 9,945 04-02-2018, 05:22 PM
  Install Influxdb & Grafana easy mrv 1 5,612 06-30-2017, 10:39 AM
Last Post: xalius
  kodi install on A64, 2GB gychang49 1 7,024 10-02-2016, 07:32 AM
Last Post: MarkHaysHarris777
  Battery and the PlayBox JoeHz 6 14,782 09-13-2016, 12:18 AM
Last Post: gperez1234
  Which OS will you install into your Pine 64? 7777777 21 40,700 04-26-2016, 12:19 PM
Last Post: Leoncito81
  Playbox Kit Question! TGCOM 8 18,084 02-22-2016, 12:13 AM
Last Post: Ghost
