Jackd triggers kernel warning
ubuntu@pine64:~$ jackd -d alsa
jackdmp 1.9.11
Copyright 2001-2005 Paul Davis and others.
Copyright 2004-2014 Grame.
jackdmp comes with ABSOLUTELY NO WARRANTY
This is free software, and you are welcome to redistribute it
under certain conditions; see the file COPYING for details
JACK server starting in realtime mode with priority 10
self-connect-mode is "Don't restrict self connect requests"
Bus error (core dumped)
ubuntu@pine64:~$
As mentioned above,jackd exited with error.
[35031.498513] Unhandled fault: alignment fault (0x92000021) at 0x0000007f9e3a508e
[35046.387455] Unhandled fault: alignment fault (0x92000021) at 0x0000007face5408e
[35286.820332] Unhandled fault: alignment fault (0x92000021) at 0x0000007fac44b08e
[35320.451564] Unhandled fault: alignment fault (0x92000021) at 0x0000007f742d408e
[35330.973834] Unhandled fault: alignment fault (0x92000021) at 0x0000007f7569008e
[35339.161052] Unhandled fault: alignment fault (0x92000021) at 0x0000007fa53de08e
[35585.840230] Unhandled fault: alignment fault (0x92000021) at 0x0000007fa63f608e
And
jackd -d alsa -d dmix
gave the same result.The dmix plugin is not working.How can we fix it up?
  PineA64+: Audio in 5.0 Kernel puzzles 6 16,446 11-13-2019, 09:41 AM
Last Post: roel
  Rockpro64 NFS root mount (kernel 4.20) - ethernet help? tenspd137 0 4,867 12-06-2018, 01:14 AM
Last Post: tenspd137
  NVMe and new kernel bjbb17 0 4,331 09-25-2018, 03:39 PM
Last Post: bjbb17
  Real-time linux kernel Artyom 45 122,028 09-11-2018, 01:08 AM
Last Post: zzwpine
  DKMS on kernel 3.10.107-pine64 obrienmd 5 14,291 06-21-2018, 05:45 PM
Last Post: evilbunny
  Kernel for A64 git longsleep 179 430,583 03-25-2018, 03:25 PM
Last Post: Luke
  Gentoo for pine64 - longsleep kernel incoherent 0 5,613 12-09-2017, 08:14 AM
Last Post: incoherent
  [SOLVED] UEFI + Fedora Mainline Kernel Booting! cztian 0 5,118 07-13-2017, 08:38 PM
Last Post: cztian
Music HOWTO: jackd on Pine64 mauritslamers 1 6,223 06-15-2017, 01:21 PM
Last Post: xalius
  Mainline kernel [Solved] jeroen79 11 29,610 02-08-2017, 06:19 AM
Last Post: umiddelb
