Kernel for A64 git
(08-10-2016, 10:34 AM)longsleep Wrote: Should not be a big deal. Please create pull request as well.
Pardon my ignorance, but I'm not quite sure what do you want me to do? If you require me to clone your repository, make the desired changes and create a pull request, I don't know how to do that, at least I don't know where to make the changes so the new modules are included...
I just pushed a new awesome Kernel release. It brings a security fix, random MAC addresses for ethernet and additional modules which were requested over the past years. For details, see the first post of this thread.
Get 3.10.102-3-pine64-longsleep-98 from https://www.stdin.xyz/downloads/people/l...ges/linux/
the new kernel does not work on Ubuntu.
Is there a way to fall back to a previous kernel ?
(08-22-2016, 04:14 PM)RaimundEge Wrote: the new kernel does not work on Ubuntu.
What do you mean? The kernel of course works with Ubuntu. Please explain. You can install any version of my kernel releases by specifying the full version number as first parameter to the ugrade script.
Thanks for all the hard work longsleep! Smile
The new kernel release works for Dietpi (At least not experienced any issues yet and my ethernet is still like half duplex gigabit so yay!)
If anyone is interested, I have forked and updated the drm kernel to 3.10.102-3.
Download Link
Source code
Donate BTC: 3Eav9uqXi8Nx1axb7QjK6xV4km4K9YGv9a
(09-16-2016, 07:30 AM)Terra854 Wrote: If anyone is interested, I have forked and updated the drm kernel to 3.10.102-3.
Download Link
Source code
Do you have something that describes the differences between longsleep's kernel and your fork?
Just wondering, because i'm a curious cat...
Download Link
Source code
The only difference is the inclusion of the DRM driver into the kernel. Other than that, it is pretty much the same.
Download Link
Source code
Not to be snarky, but you made a .config  change and called it a fork?
Download Link
Source code
I would say that it is not a fork per se, it is based on longsleep's pine64drm branch with the latest bits applied to it.
  PineA64+: Audio in 5.0 Kernel puzzles 6 16,216 11-13-2019, 09:41 AM
Last Post: roel
  Rockpro64 NFS root mount (kernel 4.20) - ethernet help? tenspd137 0 4,832 12-06-2018, 01:14 AM
Last Post: tenspd137
  NVMe and new kernel bjbb17 0 4,289 09-25-2018, 03:39 PM
Last Post: bjbb17
  Real-time linux kernel Artyom 45 120,691 09-11-2018, 01:08 AM
Last Post: zzwpine
  DKMS on kernel 3.10.107-pine64 obrienmd 5 14,161 06-21-2018, 05:45 PM
Last Post: evilbunny
  Gentoo for pine64 - longsleep kernel incoherent 0 5,565 12-09-2017, 08:14 AM
Last Post: incoherent
  [SOLVED] UEFI + Fedora Mainline Kernel Booting! cztian 0 5,070 07-13-2017, 08:38 PM
Last Post: cztian
  Mainline kernel [Solved] jeroen79 11 29,394 02-08-2017, 06:19 AM
Last Post: umiddelb
Question Need help : Issue in running compiled kernel with tftp+uboot dinesh.bhoyar 2 7,836 01-30-2017, 12:44 AM
Last Post: dinesh.bhoyar
  Jackd triggers kernel warning cztian 0 5,166 09-03-2016, 08:16 AM
Last Post: cztian
