How to set video output to 4K / UltraHD?
How do I set the video output to 4K / UltraHD on Ubuntu?
I cannot give you a definitive answer at this time; I think someone reported that the drm driver switched to 4K after reading EDID for framebuffer or X, but not sure, and don't have any 4K devices to test.
When I know something definitive about 4K, I'll post here.
I have a 4K device, so let me know what to test. Thanks.
Pander, the drm driver is capable of 4K, so have you tried it... does it go into 4K mode ?
What are the command for checking if I have it install? How to install it? How to configure it? (I am pretty handy with these things but no idea which package and config files are involved now.)
(08-10-2016, 03:53 PM)Pander Wrote: What are the command for checking if I have it install? How to install it? How to configure it? (I am pretty handy with these things but no idea which package and config files are involved now.)
I think if you are using the kernel with the new integrated drm,  your frame buffer console will have a working cursor, and it will just go into 4K by itself !
Does your frame buffer console    (  ctrl-alt-F1 )  have a working cursor?   If so, the new drm is loaded and running.
Updated all today but no cursor on text terminal yet.
$ uname -a
Linux localhost.localdomain 3.10.102-3-pine64-longsleep #98 SMP PREEMPT Sat Aug 20 22:28:17 CEST 2016 aarch64 aarch64 aarch64 GNU/Linux
$ xrandr
xrandr: Failed to get size of gamma for output default
Screen 0: minimum 1920 x 1080, current 1920 x 1080, maximum 1920 x 1080
default connected 1920x1080+0+0 0mm x 0mm
   1920x1080      0.00*
From which version number can this be expected to work?
longsleep put up another kernel build yesterday; has a security fix, several additional kernel modules, and the integrated drm (I think so).
Thanks, will test again soon.
(08-21-2016, 07:29 AM)MarkHaysHarris777 Wrote: longsleep put up another kernel build yesterday; has a security fix, several additional kernel modules, and the integrated drm (I think so).
No, only the pine64drm Kernels have the sunxi-drm display driver.
  systemd-gpt-auto-generator: failed to dissect: input/output error jeanclaude.magras@gmail.com 0 4,598 12-11-2019, 04:10 PM
Last Post: jeanclaude.magras@gmail.com
  Background Video Conversion connorja 2 6,416 07-10-2017, 12:14 PM
Last Post: connorja
  Unsupported video mode warning in dmesg utdrmac 1 5,796 02-01-2017, 01:17 PM
Last Post: MarkHaysHarris777
  cannot play any video aneryan 5 10,875 10-04-2016, 04:59 AM
Last Post: pfeerick
Question Handbrake settings for video conversion on Ubuntu Xenial pelgrim 4 11,057 08-11-2016, 07:35 AM
Last Post: waldo
  dmesg output flooded with "CPU Budget hotplug"/ "Mali: Set gpu frequency to X" cplr 2 8,236 07-13-2016, 11:18 AM
Last Post: cplr
  Video Drivers Gnx 0 3,498 07-04-2016, 04:48 PM
Last Post: Gnx
  Ubuntu: video lag romangaag 4 10,587 05-03-2016, 10:53 PM
Last Post: romangaag
  Why no DVI-HDMI video? Sequence 1 5,032 05-03-2016, 12:23 PM
Last Post: Luke
