Kinda upset at the lack of response to GBe issues
Well, we know that for a short time (due to parts shortages) they used another vendor's chip. What we need to do is identify the vendor's ieee assigned prefix.
Did you try a mac address that at least turns off the local bit ?
Second least-significant bit was 0.
Well, I think I'm making progress here.
... I have two boards (out of three) of which I am able to discuss; one of them GbE works, and one of them GbE does not work !     Blush     Pine(A) GbE works;  Pine(B)  GbE does not work.
(First off, both boards function, and both boards do 10/100 perfectly)
Pine(A)  410640133576  00:06:dc:8b:c4:0f      'GREEN'     [GbE Works]  (data below)
RTL8211E  G2K40P2  GG10B
201-A64DB110-02  A64-DB-V1.1  2G
C1600358  04.11 <----------------- note difference
CFL  _ _ _ X _
Pine(B)  410640138448  00:06:dc:8b:d7:17  'GREEN'    [GbE does not work]
RTL8211E  G3E16P1  GG128
C160358  04.12 <---------------- note difference
CFL   _ _ _ X _
The following data from iperf shows debian running iperf client to Lenovo T61 Mint Linux iperf server:
harmar@PineA64:~$ iperf -c 192.168.1.16 -t 160 -i 10
Client connecting to 192.168.1.16, TCP port 5001
TCP window size: 54.1 KByte (default)
[  3] local 192.168.1.236 port 43515 connected with 192.168.1.16 port 5001
[ ID] Interval       Transfer     Bandwidth
[  3]  0.0-10.0 sec   254 MBytes   213 Mbits/sec
[  3] 10.0-20.0 sec   254 MBytes   213 Mbits/sec
[  3] 20.0-30.0 sec   241 MBytes   202 Mbits/sec
[  3] 30.0-40.0 sec   236 MBytes   198 Mbits/sec
[  3] 40.0-50.0 sec   247 MBytes   208 Mbits/sec
[  3] 50.0-60.0 sec   198 MBytes   166 Mbits/sec
[  3] 60.0-70.0 sec   195 MBytes   164 Mbits/sec
[  3] 70.0-80.0 sec   214 MBytes   179 Mbits/sec
[  3] 80.0-90.0 sec   303 MBytes   254 Mbits/sec
[  3] 90.0-100.0 sec   181 MBytes   152 Mbits/sec
[  3] 100.0-110.0 sec   173 MBytes   145 Mbits/sec
[  3] 110.0-120.0 sec   212 MBytes   177 Mbits/sec
[  3] 120.0-130.0 sec   256 MBytes   215 Mbits/sec
[  3] 130.0-140.0 sec   293 MBytes   246 Mbits/sec
[  3] 140.0-150.0 sec   323 MBytes   271 Mbits/sec
[  3] 150.0-160.0 sec   275 MBytes   231 Mbits/sec
[  3]  0.0-160.0 sec  3.77 GBytes   202 Mbits/sec
harmar@PineA64:~$
The following data shows ubuntu (same card) running iperf client to T61 linux iperf server:
harmar@PineA64B:~$ iperf -c 192.168.1.16 -t 160 -i 10
TCP window size: 67.6 KByte (default)
[  3] local 192.168.1.239 port 57678 connected with 192.168.1.16 port 5001
[  3]  0.0-10.0 sec   470 MBytes   394 Mbits/sec
[  3] 10.0-20.0 sec   296 MBytes   248 Mbits/sec
[  3] 20.0-30.0 sec   496 MBytes   416 Mbits/sec
[  3] 30.0-40.0 sec   503 MBytes   422 Mbits/sec
[  3] 40.0-50.0 sec   526 MBytes   441 Mbits/sec
[  3] 50.0-60.0 sec   472 MBytes   396 Mbits/sec
[  3] 60.0-70.0 sec   484 MBytes   406 Mbits/sec
[  3] 70.0-80.0 sec   451 MBytes   379 Mbits/sec
[  3] 80.0-90.0 sec   508 MBytes   426 Mbits/sec
[  3] 90.0-100.0 sec   454 MBytes   381 Mbits/sec
[  3] 100.0-110.0 sec   503 MBytes   422 Mbits/sec
[  3] 110.0-120.0 sec   518 MBytes   434 Mbits/sec
[  3] 120.0-130.0 sec   511 MBytes   429 Mbits/sec
[  3] 130.0-140.0 sec   528 MBytes   443 Mbits/sec
[  3] 140.0-150.0 sec   506 MBytes   424 Mbits/sec
[  3] 150.0-160.0 sec   430 MBytes   361 Mbits/sec
[  3]  0.0-160.0 sec  7.48 GBytes   401 Mbits/sec
harmar@PineA64B:~$
All of this used the following setup:
all short cat6 cables   1M
Lenovo Mint Linux T61 notebook  server   ( iperf -s )
ubuntu & debian builds (alternately running on both pine boards as iperf -c clients)
ipv4 disabled
mac addresses as listed above, local bit set off
I will update the poll shortly;  some slight more testing to do first--- for now, I have one board that functions with GbE and one board that does not function with GbE.  The more of these we can find the better.   My boards differ in that the one that does not work has a later serial number and is marked [ 04.12 ] where-as the board that GbE functions is an earlier serial number and is marked [ 04.11 ].
So, still frustrating, yet making progress.
These numbers were obtained using the working board Pine(A) , ubuntu , while running on battery...  I almost doubled my numbers; this is repeatable !
TCP window size: 45.1 KByte (default)
[  3] local 192.168.1.239 port 57735 connected with 192.168.1.16 port 5001
[  3]  0.0-10.0 sec   728 MBytes   611 Mbits/sec
[  3] 10.0-20.0 sec   652 MBytes   547 Mbits/sec
[  3] 20.0-30.0 sec   643 MBytes   539 Mbits/sec
[  3] 30.0-40.0 sec   605 MBytes   507 Mbits/sec
[  3] 40.0-50.0 sec   649 MBytes   544 Mbits/sec
[  3] 50.0-60.0 sec   607 MBytes   509 Mbits/sec
[  3] 60.0-70.0 sec   670 MBytes   562 Mbits/sec
[  3] 70.0-80.0 sec   612 MBytes   513 Mbits/sec
[  3] 80.0-90.0 sec   644 MBytes   540 Mbits/sec
[  3] 90.0-100.0 sec   642 MBytes   539 Mbits/sec
[  3] 100.0-110.0 sec   554 MBytes   465 Mbits/sec
[  3] 110.0-120.0 sec   618 MBytes   518 Mbits/sec
[  3] 120.0-130.0 sec   601 MBytes   504 Mbits/sec
[  3] 130.0-140.0 sec   566 MBytes   475 Mbits/sec
[  3] 140.0-150.0 sec   596 MBytes   500 Mbits/sec
[  3] 150.0-160.0 sec   557 MBytes   468 Mbits/sec
[  3]  0.0-160.0 sec  9.71 GBytes   521 Mbits/sec
harmar@PineA64B:~$
... and this even though my ac power feed is filtered !   Aparently not filtered engouh for 1Gb.
(08-20-2016, 10:01 PM)amc2012 Wrote: Yes, I had gone to try longsleep's fix (he wrote to me this morning), but I am one of the lucky ones who does not have a MAC address on the bottom of my PINE. Only have a serial #. So no dice for me.
If you want to try a complete MAC, you can use the one off my board, since it's only used at the LAN level... 0006dc8b50a6
Although, since you tired the first six characters, I doubt the rest will make any difference.
Hey MarkHaysHarris777... making me jealous now... you have 2Gb pine64s... and I only have a 1Gb one! Sad
btw, the V1.1 is the same on my 1G board, but the different number you've highlighted on your two boards is 03.17 on mine... maybe it's a Month.Date of manufacture code?
(08-21-2016, 01:42 AM)pfeerick Wrote: btw, the V1.1 is the same on my 1G board, but the different number you've highlighted on your two boards is 03.17 on mine... maybe it's a Month.Date of manufacture code?
That's my guess as well.
Makes sense. Mine is 05.17, as stated in the poll thread. I got mine very late, despite being a February backer, so the 05.17 seems accurate.
I have two boards (both 2GB with wifi/bt). One works when set at 1000Mb/s. One does not work well (sporadic). I run ubuntu on the one that works and debian on the one that does not (however it does work consistently when I run at 100Mb/s).
What information can I provide that may be useful diagnostically? (and where is the poll that is mentioned?)
(08-24-2016, 05:16 PM)blairac Wrote: I have two boards (both 2GB with wifi/bt).  One works when set at 1000Mb/s.  One does not work well (sporadic).  I run ubuntu on the one that works and debian on the one that does not (however it does work consistently when I run at 100Mb/s).
The poll is at this link.
... take the poll, then read the first post (below the poll) and provide your data... both the card that works and the card that does not work.  You can vote twice, so if you have one that works, great report it.  I you have one that does not work, that's good too... report that !
(08-24-2016, 07:59 PM)MarkHaysHarris777 Wrote: You can vote twice.
No, you can't. Once you've voted (once), you can only see the results of the poll. That doesn't stop you from commenting in that thread multiple times, or indicating that with the same SD image, but with two difference devices, you get different results, etc.
I built the poll.  I also edited the poll, to allow for multiple votes (2).
... this when I realized that some folks (like myself) have multiple boards, some which work, and some that do not.
Users browsing this thread: 7 Guest(s)
