Wires as power button
Is possible to use two wires as Power and Reset Bottons? If so, in which holes I have to solder them? The more distant or closest?
If you're referring to the pc board pads, its the two closest to the edge of the board. You could certainly just use two wires without a switch, but I think you'll find that more of a hassle than you want, for a variety of reasons.
You may find this recent thread helpful: http://forum.pine64.org/showthread.php?tid=2043
... recursive link here ... Tongue
(08-19-2016, 10:20 AM)DonFL Wrote: If you're referring to the pc board pads, its the two closest to the edge of the board. You could certainly just use two wires without a switch, but I think you'll find that more of a hassle than you want, for a variety of reasons.
Yes, I know it. But I can't find this switch in my city. Definitely I will buy it on the net, but I need a temporary solution beacuse everytime I have to turn it off I have to disconnect the power supply. Thanks for the help
(08-19-2016, 12:59 PM)martinayotte Wrote: ... recursive link here ... Tongue
http://forum.pine64.org/showthread.php?tid=2032
hi, I will point out also that the best solution is to use an actual switch for both power off button , and the reset button. Any momentary close switch will work, and may be fastened to the EXP header via jumper wires.
This is a duplicate thread (closing).
Question +LTS/SOPINE USB voltage on power off using LiPo battery GregH 0 5,423 05-06-2020, 11:23 PM
Last Post: GregH
  Battery case and power question Twistedx 2 10,025 12-24-2018, 08:04 PM
Last Post: Twistedx
  Power Cord & SD Card Maximum 1 5,044 01-09-2017, 04:41 PM
Last Post: Ghost
  Can't get power button to work AidenH 17 36,810 08-28-2016, 07:19 AM
Last Post: DonFL
  Push button on/off switch Wolfenstein 6 15,186 08-01-2016, 11:05 AM
Last Post: MarkHaysHarris777
  Power Jumper rahlquist 12 27,098 04-03-2016, 09:29 AM
Last Post: SkimMilk
