lcd and hdmi dual display
any way to do both lcd and hdmi at the same time? either mirrored, or preferrably, dual displays?
i know not possible in linux (yet) but hopefully soon (lcd not working at all in linux AFAIK).
even in android this would be nice. like for using as a tablet and then plugging in hdmi to a tv to share your screen with many people, or just to plug in to watch a movie or something.
(08-06-2016, 03:11 PM)jodybrown99 Wrote: any way to do both lcd and hdmi at the same time? either mirrored, or preferrably, dual displays?
We are currently working on the Android version and will post on this month.
Mine works with both LCD and HDMI at the same time.
Is there any hope of dualbooting yet? Angel
Not in the sense of grub2 on traditional gnu+linux distributions.
... but, all I have to do to dual-boot (or quad-boot, whatever) is to pop in another SD card and power-up.  So dual booting in the sense of a desktop hard-drive is not really necessary, unless you have moved your rootfs to an ssd, hdd, or other.... and you want an easier way to get to those... but again, even so, the answer is to pop in another SD card pointing to the correct rootfs.
(08-31-2016, 01:58 PM)Chisel_86 Wrote: Mine works with both LCD and HDMI at the same time.
Which software are you using ?
Regards,
Huu Hien
Regards,
Huu Hien
What about that distribution? It is one already listed in the OS section?
android 7 does work with lcd/hdmi but you need to change a text setting in a startup file. i'm not sure of other distros.
I can't remember which one, but yes. I'm using the 64g card and I didn't change any lines of code.
Regards,
Huu Hien
  Armbian display manager issues modsbyus 0 4,680 02-08-2017, 06:18 PM
Last Post: modsbyus
  8inch display compatible to FY07024DI26A30-D mbt28 0 3,802 01-26-2017, 10:07 AM
Last Post: mbt28
  Touchscreen display mods atomicSoC 2 10,619 08-26-2016, 05:44 PM
Last Post: pfeerick
  Trouble with LCD display jdmwrx94 3 8,269 07-25-2016, 12:21 PM
Bug Raspberry Pi 7" Touchscreen Display not work? Paara 2 8,726 05-05-2016, 08:47 AM
  Touch Display Detail manny89 8 21,446 01-21-2016, 02:23 PM
Last Post: genpix
