KERNEL_SECURITY_CHECK_FAILURE at boot + no network/mouse/kb
(08-08-2016, 04:30 AM)martinzheng Wrote:
(08-07-2016, 10:30 PM)dkryder Wrote: this is from DISM.log after a failed flash. the flash process had proceeded to the 30% mark successfully before issueing the error.   the dashboard reported that the SDcard was not formatted, but of course it had been. most recently by windows after the first time this message appeared. it's a good card.  any ideas?
2016-08-07 21:16:58, Error                 DISM   FFU Provider: PID=7652 While reading image data, a hash check failed. - CFfuManager::FfuLog
2016-08-07 21:16:58, Error                 DISM   FFU Provider: PID=7652 While applying the image to disk, a read failed to return all of the blocks specified in the current data descriptor. hr = 0x2dbe260b. - CFfuManager::FfuLog
2016-08-07 21:16:58, Error                 DISM   FFU Provider: PID=7652 TID=9676 onecore\base\ntsetup\opktools\dism\providers\ffuprovider\dll\ffumanager.cpp:240 - CFfuManager::Apply(hr:0x8007000e)
2016-08-07 21:16:58, Error                 DISM   FFU Provider: PID=7652 TID=9676 onecore\base\ntsetup\opktools\dism\providers\ffuprovider\dll\ffumanager.cpp:163 - CFfuManager::ApplyImage(hr:0x8007000e)
2016-08-07 21:16:58, Error                 DISM   DISM Imaging Provider: PID=7652 TID=9676 onecore\base\ntsetup\opktools\dism\providers\imagingprovider\dll\genericimagingmanager.cpp:2581 - CGenericImagingManager::InternalCmdFFUApply(hr:0x8007000e)
2016-08-07 21:16:58, Error                 DISM   DISM Imaging Provider: PID=7652 TID=9676 onecore\base\ntsetup\opktools\dism\providers\imagingprovider\dll\genericimagingmanager.cpp:535 - CGenericImagingManager::ExecuteCmdLine(hr:0x8007000e)
2016-08-07 21:16:58, Info                  DISM   DISM.EXE: Image session has been closed. Reboot required=no.
2016-08-07 21:16:58, Info                  DISM   DISM.EXE: <----- Ending Dism.exe session ----->
This is because the ffu file that you are using is broken. I think Tim would update a new image.
Sorry on the  broken ffu file, I have already reload the full 1.1GB ffu file to wiki server and please download again. Here is the link: http://files.pine64.org/os/win10-iot/Win...Pine64.ffu
(08-08-2016, 07:34 AM)dkryder Wrote: the file on the pine64 site is 300MB, the file on onedrive is no longer there.
Using an USB hub and USB2Ethernet adapter I had lying around I indeed seem to be able to have keyboard, mouse and networking! Smile
(08-08-2016, 10:28 AM)rookieone Wrote: Using an USB hub and USB2Ethernet adapter I had lying around I indeed seem to be able to have keyboard, mouse and networking! Smile
Great !!!
That onedrive account has been forbidden for 24 hours because of a big mount of visit. Lim will update the ffu soon I think
ok. yes, i was able to download the ffu. thank you,   tllim, for putting it up. i was able to boot , however had problems with provisioning and as a result had everthing but internet working. i am using a usb hub with wireless keyboard/trackpad and hub has ethernet jack but i think microsoft keeps net access off until the device is properly provisioned. i have no ip address at this point. the hub works fine with debian so i know the hardware is ok. not sure what i can do. i'd rather not flash again.
A hub with Ethernet? Do you know which Ethernet chip it uses? currently, IoT core can support ax88772.
https://www.amazon.com/gp/product/B0178H...UTF8&psc=1
http://www.tecknet.co.uk/hu043.html
i'll try to locate info you want. this works great out of box with debian build. i'm able to bind 2 ethernet feeds into one very strong feed.
i think it is realtek RTL8153
http://www.realtek.com.tw/products/produ...ProdID=326
#19
Is it possible for the IoT Core to support the rtl8201cp and rtl8211e chips that are present in Pine A64+ so that it is able to natively support ethernet without the need for a converter.
Donate BTC: 3Eav9uqXi8Nx1axb7QjK6xV4km4K9YGv9a
#20
(08-09-2016, 04:43 AM)Terra854 Wrote: Is it possible for the IoT Core to support the rtl8201cp and rtl8211e chips that are present in Pine A64+ so that it is able to natively support ethernet without the need for a converter.
Actually that is what we are working on now.
Sad I cant connect to the network. MasahiroSakashita 3 9,792 01-25-2017, 11:54 AM
Last Post: MarkHaysHarris777
