07-29-2016, 11:17 AM
Lenny,
That is super exciting. Thank you so much for your hard work on this!
HW Acceleration Working
Lenny,
07-29-2016, 02:40 PM
Awesome, even more so because I read it in Vegeta's voice
07-29-2016, 04:16 PM
(07-29-2016, 11:17 AM)jl_678 Wrote: Lenny, I second that jl_678!!!! The work of Lenny and others in this matter makes me proud to be in this community. I wish I knew more so that I could contribute more. To me this will be the killer feature of Pine64 over RPI3. Exciting days ahead!!!
07-29-2016, 09:14 PM
(This post was last modified: 07-29-2016, 09:31 PM by lenny.raposo-pine64.pro.)
Ladies and gentlemen
![]() I mean we have the Mali working ![]() ![]()
If you like my work be sure to check out my site or wish to donate to the cause
Cheers ![]()
07-29-2016, 09:18 PM
You heard it here first, folks!
![]() Lenny has ascended to god status, me thinks.
Community administrator and sysadmin for PINE64
07-29-2016, 09:25 PM
(This post was last modified: 07-29-2016, 09:30 PM by lenny.raposo-pine64.pro.)
This was a huge team effort.
Big thanks needs to go out to Xalius (without you I would have missed the fact I was using the wrong kernel module), longsleep (for starting all this, without your kernel work we wouldn't be where we are at), ssvb + mripard + apritzel (for taking the time in educating me on how it all works) and our soldier in the front lines Mr. TL Lim (this man has gone above and beyond in getting us what we need to get this far with development). I would also like to say thanks to the Jet from AllWinner (those DTS entries helped alot and the drm portions worked out). Now onto cleanup and mass distribution of this update .
Cheers ![]()
07-30-2016, 01:03 AM
Wow! Big Thanks to all mentioned and for all your hard work Lenny!
Sent from my iPad using Tapatalk
07-30-2016, 02:20 AM
This is fantastic! Thank you so much for all your work!
07-30-2016, 02:41 AM
Heh, the latest and greatest Mali blob version still has a "segfault on exit" problem, based on your log of running "es2_info". Apparently not much has changed in the code quality department since r3pX times and the blobs are still expected to be full of bugs
![]() Now after everything is wrapped up, hopefully with a missing EULA notice added to allow legal redistribution of the binary, it will be a good time for fixing performance problems in the X11 integration. Having merely 100 FPS in es2_gears is definitely not impressive. For comparison, an old Allwinner A10 using the Mali400 with a single pixel processor (Allwinner A64 has two pixel processors) and running at a lower Mali clock speed 320MHz could show much better performance with xf86-video-fbturbo. Also, as already mentioned earlier, some popular applications (such as Kodi) want the framebuffer variant of the Mali binary drivers rather than the X11 variant. |
| Brand New LCD not working | adamjedgar | 3 | 11,752 |
03-11-2017, 12:20 AM Last Post: simplexdan |
| Pine64+: 3 working, 1 shows nothing on tv | zumtra | 1 | 6,770 |
07-30-2016, 05:47 PM Last Post: tllim |
