Play music won't play anything
I've got the stock 5.1.1 which came with my pine. I cannot get google play music to play anything I have to use the browser instead. Has anyone else run into this? Solutions? I will try to debug it with a wifi adblog app tonight or tomorrow.
everything else seems to work. Odd bugs I've found:
over time the headphone jack unregisters as not being plugged in.
Wifi drops eventually and have to manually reconnect.
cheers
Backer #6878
shipment status: arrived
Are you using the hdmi video, or LCD?
... are you using audio jack, or hdmi audio?
marcus
(07-06-2016, 03:44 PM)MarkHaysHarris777 Wrote: Are you using the hdmi video, or LCD?
marcus
Audio jack
When I say it won't play it literally starts skipping tracks and infinitely loads
Backer #6878
marcus
Audio jack
The guys trying to get it to passthrough in Kodi (to their AVR) are having the same issue skipping, &c.
Will it play via hdmi audio?
marcus
Audio jack
I'll give it a try tonight when I am home. youtube app works fine.
Backer #6878
unplugging the audio cable makes no difference. I will try to get an adb log soon, too late tonight to do that.
Backer #6878
Logcat post
http://pastebin.com/5sMjYcKE
Also note more issues with mounting extsd
07-08 00:41:39.473 E/Vold (1623): Failed to find mounted volume for /storage/extsd/Android/data/com.google.android.music/files/
07-08 00:41:39.473 W/Vold (1623): Returning OperationFailed - no handler for errno 0
07-08 00:41:39.475 W/ContextImpl(18187): Failed to ensure directory: /storage/extsd/Android/data/com.google.android.music/files
(07-07-2016, 10:50 PM)Raslin777@gmail.com Wrote: Logcat post
Thanks for that, yes the being unable to cache music probably doesn't help with being able to stream. I still need to figure out how to adb this thing, how did you do it?
Backer #6878
Using catlog atm until I update my xposed apps to lollipop(on KitKat now).
https://play.google.com/store/apps/detai...son.logcat
Also would recommend.
Liveboot
https://play.google.com/store/apps/detai...e.liveboot
I'm going to symlink that empty folder to the correct location. Hopefully it is fixed on the next build. (if only it wasn't read only)
Backer #6878
Thumbs Up Kids love to Play Super Why App Erica Edwards 3 7,294 01-09-2017, 07:35 PM
  play store auth issue chrwei 29 51,706 09-09-2016, 11:02 AM
Last Post: eldaria
  Can't download apps off Google Play! Bacon Strips 6 13,369 08-31-2016, 12:26 PM
Last Post: DonFL
  Games in Play Store top3b 2 5,925 07-26-2016, 12:40 PM
Last Post: top3b
  Play Store stops running every time thehamguy1 15 26,921 07-10-2016, 01:04 PM
Last Post: Raslin777@gmail.com
  Can't play movies from Google Play Store wappi 11 23,210 07-10-2016, 12:47 PM
  Widescreen gaming in Google Play DwyerSP 1 5,167 06-30-2016, 11:22 AM
Last Post: Tarjei85
Question Play Store Searches pwneboi 0 2,770 06-14-2016, 11:18 AM
Last Post: pwneboi
  Play store crash Bumlock 4 8,161 05-19-2016, 09:02 AM
Last Post: Ziehlneelsen
Question no more access to google play bongo 3 6,782 05-16-2016, 01:11 PM
Last Post: bongo
