Python access from the menu
Like I used to do in raspberrypi 3, I can able to select python from the menu and run the program and I can test the program by click on RUn button and it opens up second windows.
Is it possible for me to get python program on menu or same as pi?
I am new to Linux and learning a lot from the forum.
if you are using the debian mate image
try the following
sudo apt-get install mate-desktop-environment-extra mate-desktop-environment-extras
sudo reboot
once you are logged back into the desktop environment simply right click on the Applications menu then select Edit Menus
Then enable the Python option under the Programming sub menu item Wink
If you like my work be sure to check out my site or wish to donate to the cause
Cheers Big Grin
(06-27-2016, 04:30 PM)lenny.raposo-pine64.pro Wrote: if you are using the debian mate image
try the following
sudo reboot
WOW. Thanks for quick response. It solved my problem.
BTW, how about doing the same thing on Ubuntu Xenial BSP build?  Is it possible?( I have another SD card and I have installed Ubuntu.)
Thanks again..
  Recovering root access in Ubuntu Scientomancer 3 10,608 07-28-2017, 02:53 PM
Last Post: Scientomancer
  dual wifi, one as access point vigor 0 3,953 09-02-2016, 11:55 PM
Last Post: vigor
  How do i install python anaconda on my ubuntu ? quantumfusion 3 10,471 08-22-2016, 08:07 AM
Last Post: martinayotte
Bug Map menu key to menu in XFCE Pander 6 12,340 08-10-2016, 07:47 AM
Last Post: Pander
  Network Access Error coolnine98 5 12,639 06-29-2016, 06:15 PM
Last Post: coolnine98
  Remote access to Mate desktop using VNC jl_678 2 8,488 05-09-2016, 09:31 PM
