DD image or rooted DD image
i'm a noob in these things but which image do I need to download/use? The DD image or the rooted DD image? What is the difference?
Txs for helping
(06-21-2016, 03:41 AM)Eastwood Wrote: Hello,
Txs for helping
The rooted image allows you more control over the Android OS. But if you happily use your phone / tablet without having it rooted, then you should be fine just a standard DD image.
As I understand it, some apps will only work if rooted. Others will only work if not rooted.
Just remember, if you are downloading a DD image, you cannot use PhoenixCard to burn it. You will need to use either the dd command in a terminal (Linux/Mac), or Win32DiskImager, or something similar like Rufus (Windows).
  Reducing Android Image download size. KPhillisJr 4 13,279 08-21-2017, 04:48 AM
Last Post: winstongel
  Is there an android tv image out there where I can install netflix? eclay 2 9,578 07-18-2017, 08:49 AM
Last Post: eclay
  Android 6.0.1 Image (LCD and HDMI Video Output) Release 20170209 [ver 2.0.1] rookieone 15 36,187 05-05-2017, 01:50 AM
Last Post: Quezbeme
  android image & sd card size problems tomarneson 11 27,994 01-24-2017, 05:31 AM
Last Post: ayufan
  ethernet does not work with Android 5.1.1 Image Release 20160711 (Known Problem) mathiraj 18 38,175 10-29-2016, 04:31 AM
Last Post: joe
  buring image with 'dd' on linux doesn't work (Solved) mathiraj 2 8,459 10-17-2016, 11:42 AM
Last Post: mathiraj
  Setting up SD card and installing rooted Android using an ubuntu machine edszr.co 4 10,798 09-22-2016, 03:56 PM
Last Post: edszr.co
  burning Android SD image with Ubuntu... Jessica Spongekipper 0 3,340 09-16-2016, 01:46 AM
Last Post: Jessica Spongekipper
Question Rooted Android 5.1.1 - Phone, Dialler & SMS Green Cherry 2 7,130 09-10-2016, 08:14 PM
Last Post: dkryder
  Can I rotate Screen Android 5.1.1 for LCD (not rooted) steveslim 4 12,379 09-04-2016, 09:35 PM
Last Post: steveslim
