Not a single smooth image
I waited 6 months to get this piece of hardware. Out of the box, I can't find any image working properly (not lagging)
In the demos, Pine has shown android to work smoothly in brilliant 4k when in reality it suffers in processing 1080p. Is there a single Android image which work smoothly ?
What kind of MicroSD card are you using? I'd use a class 10.
Keep in mind that though you can reach the sequential read/write limit with a lot of say class 10 cards, but there is sadly no specification for random read/write performance which influences the experience on single board computers / application type setups. Check the stickied thread on how to measure, some very expensive cards have good linear read/write performance but fail horribly at random I/O because what they are usually optimized for is writing linear image and video streams in cameras... from my experience it makes a lot of difference with Android as well. http://forum.pine64.org/showthread.php?tid=191&page=8 , http://forum.armbian.com/index.php/topic...rformance/
(06-20-2016, 01:09 PM)xalius Wrote: Keep in mind that though you can reach the sequential read/write limit with a lot of say class 10 cards, but there is sadly no specification for random read/write performance which influences the experience on single board computers / application type setups. Check the stickied thread on how to measure, some very expensive cards have good linear read/write performance but fail horribly at random I/O because what they are usually optimized for is writing linear image and video streams in cameras... from my experience it makes a lot of difference with Android as well. http://forum.pine64.org/showthread.php?tid=191&page=8 , http://forum.armbian.com/index.php/topic...rformance/
Which SD card would you recommend ?
I would like to run Kodi off my pine64. AFAIK, this random I/O speed doesn't affect Raspberry Pi's ?
  Reducing Android Image download size. KPhillisJr 4 12,994 08-21-2017, 04:48 AM
Last Post: winstongel
  Is there an android tv image out there where I can install netflix? eclay 2 9,377 07-18-2017, 08:49 AM
Last Post: eclay
  Android 6.0.1 Image (LCD and HDMI Video Output) Release 20170209 [ver 2.0.1] rookieone 15 35,378 05-05-2017, 01:50 AM
Last Post: Quezbeme
  android image & sd card size problems tomarneson 11 27,355 01-24-2017, 05:31 AM
Last Post: ayufan
  ethernet does not work with Android 5.1.1 Image Release 20160711 (Known Problem) mathiraj 18 37,477 10-29-2016, 04:31 AM
Last Post: joe
  buring image with 'dd' on linux doesn't work (Solved) mathiraj 2 8,291 10-17-2016, 11:42 AM
Last Post: mathiraj
  burning Android SD image with Ubuntu... Jessica Spongekipper 0 3,269 09-16-2016, 01:46 AM
Last Post: Jessica Spongekipper
  Can't read SD card on Mac/Win after mounting DD Android image Voyager 3 8,863 09-04-2016, 12:05 PM
Last Post: Boring
  MicroSD Size mismatch with Image Hbtr 23 46,505 08-31-2016, 09:00 AM
Last Post: montero65
  Android 5.1.1 Image Release 20160711 clarkss12 27 54,192 08-27-2016, 08:14 AM
Last Post: neyron
