bookworm vs trixie discussion for mobian in pinephone regular.
#71
Exclamation
When I succeed in using the installer and upgrading to Mobian Trixie, I end up with a command line access and no desktop environment, it's a waste of time, it's no longer a matter of partition size even though the small boot partition is a problem to achieve all this. That's why I'm forced to use an image and Tow-Boot as you said, light blue, etc. I know that it's possible to encrypt the home partition after the installation, I just don't know exactly how to do that, I'm trying to learn, it would be very helpful for people like me who need full disk encryption.
(09-21-2025, 11:18 AM)anonymous Wrote: When I succeed in using the installer and upgrading to Mobian Trixie, I end up with a command line access and no desktop environment, it's a waste of time, it's no longer a matter of partition size even though the small boot partition is a problem to achieve all this. That's why I'm forced to use an image and Tow-Boot as you said, light blue, etc. I know that it's possible to encrypt the home partition after the installation, I just don't know exactly how to do that, I'm trying to learn, it would be very helpful for people like me who need full disk encryption.
No,
1- from your computer via USB make an encrypted container when you are in blue light mode
2 - then load your working OS onto that Calamares container.
let us know if this breaks because I have done exactly that for SD cards before.
Exclamation
I know how to create a LUKS2 encrypted partition but I don't know how to create a Calamares container, I will look at the documentation.
P.S: mobian-sunxi-phosh-20251005.img.xz doesn't work, I just get "pinephone-keyboard 3-0015: Failed to read device ID: -6". mobian-sunxi-phosh-20251002.img.xz seems to work (with Wifi support). I've updated my instructions about encryption here, some steps are missing but encrypting the partition seems to work.
P.S 2: After doing almost the same thing than setup-luks.sh in the installer, I get "pinephone-keyboard 3-0015: Failed to read device ID: -6" Sad
mobian has released trixie, release number is 13.
that practically means that using bookworm is not useful anymore, it is now oldstable.
in the future, choice will be in between forky 14 and trixie 13.
https://blog.mobian.org/posts/2025/10/ne...ting-keys/
Oldstable remains supported with regular updates for a few months, then LTS and then ELTS updates. But of course, running stuff that old on a phone is not all that great because mobile GNU/Linux moves fast.
Exclamation
I've just installed Mobian Trixie on the latest Pinephone I bought, I used the 2 latest weekly images (12 and 19 October 2025), it doesn't ask for my PIN code. I did the same on my previous Pinephone, it asks for my PIN code but the modem seems to die after several minutes Sad I'm stuck with the Librem 5, I'm forced to make a phone call each time I need to wake up the modem Sad
(10-17-2025, 02:32 AM)zetabeta Wrote: mobian has released trixie, release number is 13.
I confirm that the installer generated by following the instructions in this article works, I have Mobian Trixie with full disc encryption anew Smile I still have a problem with my modem.
You can check my guide to upgrading form Trixie(new stable) to Forky(testing) here
https://forum.pine64.org/showthread.php?tid=20047
(11-20-2023, 07:06 AM)Zebulon Walton Wrote: So far I've been sticking with bookworm for the stability. Since I only use the Pinephone for phone calls having that basic function working is my primary concern. However there are some rough edges in bookworm that, if fixed in trixie, might motivate me to switch.
<snipped>
Funnily enough I can finally make phone calls again on my PinePhone when running on trixie. I am trialling trixie by running on an SD card which might explain why the call quality was so bad. Performance issues related to the OS running from an SD card?
bookworm is currently installed on the eMMC and call quality was good enough when it was working.
Edit : I noticed in this thread that adjusting the microphone levels might help. I will do some test calls to see if it has.
Edit 2 ; sound quality in calls is improved by lowering the mic level in the sound settings. It is now usable.
To get it done quickly I grabbed, USB loaded, and ran a convenient installer image to setup calmares.
Once it was installed and the OS loaded I just loaded my disc image onto the calmares container.
loading a PPpro takes about 3 hours to do 128GB image over a USB cable.
  Mobian MMS/SMS text problem bcnaz 16 34,740 06-23-2026, 06:53 AM
Last Post: mehdy
  Mobian image for the PinePhone Korfou 2 928 04-27-2026, 09:57 AM
Last Post: Korfou
  Trixie - bring up the On Screen Keyboard manually. grump_fiddle_reinstall 0 756 12-23-2025, 04:34 AM
  camera not usable with trixie? JChdeL 0 677 12-05-2025, 01:45 AM
Last Post: JChdeL
  trixie update poll questions suggestions j_s 5 2,041 10-22-2025, 07:14 AM
Last Post: anonymous
  cryptocurrency on mobian/pinephone biketool 33 69,049 10-08-2025, 06:21 AM
  XLibre for Mobian Hiraghm 0 2,863 06-29-2025, 12:38 PM
Last Post: Hiraghm
  Axolotl on PinePhone / Mobian arno_nuehm 223 325,292 06-25-2025, 01:19 PM
  VoIP account on mobian dialer j_s 0 2,563 06-15-2025, 04:19 PM
Last Post: j_s
  Mobian Pinephone Notification LED biketool 2 3,471 06-07-2025, 03:19 PM
