StarPro64 Irradium (based on crux linux) riscv64, aarch64
irradium - source based Linux distribution CRUX adhering to ideology keep it simple, has its own package system, also supports the port system.
irradium development
packages aarch64
packages riscv64
installation README.TXT
kernel 6.6.88
mirror 1, mirror 2, mirror 3
irradium-3.8-riscv64-core-starpro64-6.6.88-build-20250714.img.zst
irradium-3.8-riscv64-core-starpro64-6.6.88-build-20250714.img.zst.sha256
irradium-3.8-riscv64-xfce-starpro64-6.6.88-build-20250714.img.zst
irradium-3.8-riscv64-xfce-starpro64-6.6.88-build-20250714.img.zst.sha256
donation   irradium
kernel 6.6.88
mirror 1, mirror 2, mirror 3, mirror 4
irradium-3.8-riscv64-core-starpro64-6.6.99-build-20250718.img.zst
irradium-3.8-riscv64-core-starpro64-6.6.99-build-20250718.img.zst.sha256
irradium-3.8-riscv64-xfce-starpro64-6.6.99-build-20250718.img.zst
irradium-3.8-riscv64-xfce-starpro64-6.6.99-build-20250718.img.zst.sha256
donation   irradium
kernel 6.6.99
irradium-3.8-riscv64-core-starpro64-6.6.99-build-20250723.img.zst
irradium-3.8-riscv64-core-starpro64-6.6.99-build-20250723.img.zst.sha256
irradium-3.8-riscv64-xfce-starpro64-6.6.99-build-20250723.img.zst
irradium-3.8-riscv64-xfce-starpro64-6.6.99-build-20250723.img.zst.sha256
donation   irradium
kernel 6.16.0
irradium-3.8-riscv64-core-starpro64-6.16.0-build-20250802.img.zst
irradium-3.8-riscv64-core-starpro64-6.16.0-build-20250802.img.zst.sha256
HDMI output not working
Starting kernel ...
[    0.000000] Booting Linux on hartid 3
[    0.000000] Linux version 6.16.0 (root@irradium-build) (riscv64-unknown-linux-gnu-gcc (crosstool-NG 1.26.0) 13.2.0, GNU ld (crosstool-NG 1.26.0) 2.40) #1 SMP PREEMPT_DYNAMIC Sat Aug  2 08:45:57 UTC 2025
[    0.000000] Machine model: Pine64 StarPro64
[    0.000000] SBI specification v0.3 detected
[    0.000000] SBI implementation ID=0x1 Version=0x10000
[    0.000000] SBI TIME extension detected
[    0.000000] SBI IPI extension detected
[    0.000000] SBI RFENCE extension detected
[    0.000000] SBI SRST extension detected
[    0.000000] efi: UEFI not found.
[    0.000000] Reserved memory: created CMA memory pool at 0x00000002dfe00000, size 512 MiB
[    0.000000] OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool
[    0.000000] OF: reserved mem: 0x00000002dfe00000..0x00000002ffdfffff (524288 KiB) map reusable linux,cma
[    0.000000] OF: reserved mem: 0x00000000dfff0000..0x00000000dfffffff (64 KiB) nomap non-reusable lpcpures@dfff0000
[    0.000000] OF: reserved mem: 0x00000000e0000000..0x00000000e1ffffff (32768 KiB) nomap non-reusable region@e0000000
[    0.000000] OF: reserved mem: 0x0000001000000000..0x00000010003fffff (4096 KiB) map non-reusable mmode_resv1@10,0
[    0.000000] OF: reserved mem: 0x0000000080000000..0x000000008007ffff (512 KiB) map non-reusable mmode_resv0@80000000
[    0.000000] OF: reserved mem: 0x0000000059000000..0x00000000593fffff (4096 KiB) nomap non-reusable sprammemory@59000000
[    0.000000] OF: reserved mem: 0x00000000a0000000..0x00000000a00fffff (1024 KiB) nomap non-reusable lpcpu@a0000000
[    0.000000] OF: reserved mem: 0x00000000fffff000..0x00000000ffffffff (4 KiB) nomap non-reusable g2d_4GB_boundary_reserved_4k
[    0.000000] OF: reserved mem: 0x00000001fffff000..0x00000001ffffffff (4 KiB) nomap non-reusable g2d_8GB_boundary_reserved_4k
[    0.000000] OF: reserved mem: 0x00000002fffff000..0x00000002ffffffff (4 KiB) nomap non-reusable g2d_12GB_boundary_reserved_4k
[    0.000000] OF: reserved mem: 0x0000000300000000..0x000000047fffffff (6291456 KiB) nomap non-reusable mmz_nid_0_part_0
[    0.000000] Zone ranges:
[    0.000000]   DMA32    [mem 0x0000000059000000-0x00000000ffffffff]
[    0.000000]   Normal   [mem 0x0000000100000000-0x000000087fffffff]
[    0.000000] Movable zone start for each node
[    0.000000] Early memory node ranges
[    0.000000]   node   0: [mem 0x0000000059000000-0x00000000593fffff]
[    0.000000]   node   0: [mem 0x0000000080000000-0x000000009fffffff]
[    0.000000]   node   0: [mem 0x00000000a0000000-0x00000000a00fffff]
[    0.000000]   node   0: [mem 0x00000000a0100000-0x00000000dffeffff]
[    0.000000]   node   0: [mem 0x00000000dfff0000-0x00000000e1ffffff]
[    0.000000]   node   0: [mem 0x00000000e2000000-0x00000000ffffefff]
[    0.000000]   node   0: [mem 0x00000000fffff000-0x00000000ffffffff]
[    0.000000]   node   0: [mem 0x0000000100000000-0x00000001ffffefff]
[    0.000000]   node   0: [mem 0x00000001fffff000-0x00000001ffffffff]
[    0.000000]   node   0: [mem 0x0000000200000000-0x00000002ffffefff]
[    0.000000]   node   0: [mem 0x00000002fffff000-0x000000047fffffff]
[    0.000000]   node   0: [mem 0x0000000480000000-0x000000087fffffff]
[    0.000000] Initmem setup node 0 [mem 0x0000000059000000-0x000000087fffffff]
[    0.000000] On node 0, zone DMA32: 4096 pages in unavailable ranges
[    0.000000] On node 0, zone DMA32: 27648 pages in unavailable ranges
[    0.000000] SBI HSM extension detected
[    0.000000] Using physical memory alias for noncached mappings
[    0.000000] riscv: base ISA extensions acdfhim
[    0.000000] riscv: ELF capabilities acdfim
[    0.000000] Ticket spinlock: enabled
[    0.000000] percpu: Embedded 54 pages/cpu s94488 r8192 d118504 u221184
[    0.000000] pcpu-alloc: s94488 r8192 d118504 u221184 alloc=54*4096
[    0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
[    0.000000] Kernel command line: root=UUID=32539e08-a5c0-4084-9f32-0932043d95e3 ro rootwait rootfstype=ext4 console=ttyS0,115200n8 console=tty1 consoleblank=0 loglevel=8 earlycon=sbi clk_ignore_unused usb-storage.quirks=   clk_ignore_unused
[    0.000000] printk: log buffer data + meta data: 262144 + 917504 = 1179648 bytes
[    0.000000] Dentry cache hash table entries: 4194304 (order: 13, 33554432 bytes, linear)
[    0.000000] Inode-cache hash table entries: 2097152 (order: 12, 16777216 bytes, linear)
[    0.000000] software IO TLB: area num 4.
[    0.000000] software IO TLB: mapped [mem 0x00000000fbfff000-0x00000000fffff000] (64MB)
[    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 8389632
[    0.000000] mem auto-init: stack:all(zero), heap alloc:off, heap free:off
[    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[    0.000000] Dynamic Preempt: voluntary
[    0.000000] rcu: Preemptible hierarchical RCU implementation.
[    0.000000] rcu:     RCU restricting CPUs from NR_CPUS=32 to nr_cpu_ids=4.
[    0.000000]  Trampoline variant of Tasks RCU enabled.
[    0.000000]  Tracing variant of Tasks RCU enabled.
[    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
[    0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=4
[    0.000000] RCU Tasks: Setting shift to 2 and lim to 1 rcu_task_cb_adjust=1 rcu_task_cpu_ids=4.
[    0.000000] RCU Tasks Trace: Setting shift to 2 and lim to 1 rcu_task_cb_adjust=1 rcu_task_cpu_ids=4.
[    0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
[    0.000000] riscv-intc: 64 local interrupts mapped
[    0.000000] riscv: providing IPIs using SBI IPI extension
[    0.000000] rcu: srcu_init: Setting srcu_struct sizes based on contention.
[    0.000000] clocksource: riscv_clocksource: mask: 0xffffffffffffffff max_cycles: 0x1d854df40, max_idle_ns: 3526361616960 ns
[    0.000003] sched_clock: 64 bits at 1000kHz, resolution 1000ns, wraps every 2199023255500ns
[    0.000969] Console: colour dummy device 80x25
[    0.000984] printk: legacy console [tty1] enabled
[    0.001568] Calibrating delay loop (skipped), value calculated using timer frequency.. 2.00 BogoMIPS (lpj=4000)
[    0.001595] pid_max: default: 32768 minimum: 301
[    0.003693] LSM: initializing lsm=lockdown,capability,landlock,yama,apparmor,ima,evm
[    0.004602] landlock: Up and running.
[    0.004623] Yama: becoming mindful.
[    0.005026] AppArmor: AppArmor initialized
[    0.006444] Mount-cache hash table entries: 65536 (order: 7, 524288 bytes, linear)
[    0.006547] Mountpoint-cache hash table entries: 65536 (order: 7, 524288 bytes, linear)
[    0.013423] ASID allocator disabled (0 bits)
[    0.013694] rcu: Hierarchical SRCU implementation.
[    0.013718] rcu:     Max phase no-delay instances is 1000.
[    0.014252] Timer migration: 1 hierarchy levels; 8 children per group; 1 crossnode level
[    0.015014] EFI services will not be available.
[    0.015836] smp: Bringing up secondary CPUs ...
[    0.020040] smp: Brought up 1 node, 4 CPUs
[    0.020359] Memory: 25988908K/33558528K available (12988K kernel code, 8844K rwdata, 6144K rodata, 6242K init, 1333K bss, 7038944K reserved, 524288K cma-reserved)
[    0.025442] devtmpfs: initialized
[    0.045184] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[    0.045293] posixtimers hash table entries: 2048 (order: 3, 32768 bytes, linear)
[    0.045351] futex hash table entries: 1024 (65536 bytes on 1 NUMA nodes, total 64 KiB, linear).
[    0.051769] pinctrl core: initialized pinctrl subsystem
[    0.052779] DMI not present or invalid.
[    0.054889] NET: Registered PF_NETLINK/PF_ROUTE protocol family
[    0.055851] DMA: preallocated 4096 KiB GFP_KERNEL pool for atomic allocations
[    0.055961] DMA: preallocated 4096 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
[    0.056091] audit: initializing netlink subsys (disabled)
[    0.056597] audit: type=2000 audit(0.056:1): state=initialized audit_enabled=0 res=1
[    0.057312] thermal_sys: Registered thermal governor 'fair_share'
[    0.057325] thermal_sys: Registered thermal governor 'bang_bang'
[    0.057345] thermal_sys: Registered thermal governor 'step_wise'
[    0.057357] thermal_sys: Registered thermal governor 'user_space'
[    0.057368] thermal_sys: Registered thermal governor 'power_allocator'
[    0.057520] cpuidle: using governor ladder
[    0.057624] cpuidle: using governor menu
[    0.080519] cpu2: Ratio of byte access time to unaligned word access is 0.00, unaligned accesses are slow
[    0.080521] cpu1: Ratio of byte access time to unaligned word access is 0.00, unaligned accesses are slow
[    0.080520] cpu3: Ratio of byte access time to unaligned word access is 0.00, unaligned accesses are slow
[    0.104627] cpu0: Ratio of byte access time to unaligned word access is 0.00, unaligned accesses are slow
[    0.104881] CCACHE: 4 banks, 16 ways, sets/bank=1024, bytes/block=64
[    0.104903] CCACHE: Index of the largest way enabled: 15
[    0.115031] /soc/i2c@50950000/es8388-0@10: Fixed dependency cycle(s) with /soc/i2s1@50210000
[    0.115408] /soc/i2s0@50200000: Fixed dependency cycle(s) with /soc/hdmi@502a0000
[    0.115434] /soc/i2s1@50210000: Fixed dependency cycle(s) with /soc/i2c@50950000/es8388-0@10
[    0.115470] /soc/display_control@502c0000: Fixed dependency cycle(s) with /soc/hdmi@502a0000
[    0.115488] /soc/display_control@502c0000: Fixed dependency cycle(s) with /soc/es_wb
[    0.115507] /soc/display_control@502c0000: Fixed dependency cycle(s) with /soc/mipi_dsi@50270000
[    0.115546] /soc/es_wb: Fixed dependency cycle(s) with /soc/display_control@502c0000
[    0.115577] /soc/mipi_dsi@50270000: Fixed dependency cycle(s) with /soc/display_control@502c0000
[    0.115605] /soc/hdmi@502a0000: Fixed dependency cycle(s) with /soc/i2s0@50200000
[    0.115629] /soc/hdmi@502a0000: Fixed dependency cycle(s) with /soc/display_control@502c0000
[    0.115714] /soc/csidma@0x52048000: Fixed dependency cycle(s) with /soc/csi2@51050000
[    0.115742] /soc/csi2@51050000: Fixed dependency cycle(s) with /soc/csidma@0x52048000
[    0.191681] /soc/i2c@50950000/es8388-0@10: Fixed dependency cycle(s) with /soc/i2s1@50210000
[    0.193152] eswin-pinctrl 51600080.pinctrl: eswin pinctrl initialized
[    0.194893] /soc/i2s0@50200000: Fixed dependency cycle(s) with /soc/hdmi@502a0000
[    0.195067] /soc/i2c@50950000/es8388-0@10: Fixed dependency cycle(s) with /soc/i2s1@50210000
[    0.195118] /soc/i2s1@50210000: Fixed dependency cycle(s) with /soc/i2c@50950000/es8388-0@10
[    0.195471] /soc/display_control@502c0000: Fixed dependency cycle(s) with /soc/hdmi@502a0000
[    0.195491] /soc/display_control@502c0000: Fixed dependency cycle(s) with /soc/es_wb
[    0.195509] /soc/display_control@502c0000: Fixed dependency cycle(s) with /soc/mipi_dsi@50270000
[    0.195687] /soc/display_control@502c0000: Fixed dependency cycle(s) with /soc/es_wb
[    0.195736] /soc/es_wb: Fixed dependency cycle(s) with /soc/display_control@502c0000
[    0.195919] /soc/display_control@502c0000: Fixed dependency cycle(s) with /soc/mipi_dsi@50270000
[    0.195969] /soc/mipi_dsi@50270000: Fixed dependency cycle(s) with /soc/display_control@502c0000
[    0.196192] /soc/display_control@502c0000: Fixed dependency cycle(s) with /soc/hdmi@502a0000
[    0.196251] /soc/i2s0@50200000: Fixed dependency cycle(s) with /soc/hdmi@502a0000
[    0.196297] /soc/hdmi@502a0000: Fixed dependency cycle(s) with /soc/i2s0@50200000
[    0.196343] /soc/hdmi@502a0000: Fixed dependency cycle(s) with /soc/display_control@502c0000
[    0.197775] /soc/csidma@0x52048000: Fixed dependency cycle(s) with /soc/csi2@51050000
[    0.197924] /soc/csidma@0x52048000: Fixed dependency cycle(s) with /soc/csi2@51050000
[    0.197981] /soc/csi2@51050000: Fixed dependency cycle(s) with /soc/csidma@0x52048000
[    0.206388] HugeTLB: allocation took 0ms with hugepage_allocation_threads=1
[    0.206418] HugeTLB: registered 1.00 GiB page size, pre-allocated 0 pages
[    0.206428] HugeTLB: 16380 KiB vmemmap can be freed for a 1.00 GiB page
[    0.206440] HugeTLB: registered 2.00 MiB page size, pre-allocated 0 pages
[    0.206449] HugeTLB: 28 KiB vmemmap can be freed for a 2.00 MiB page
[    0.216704] fbcon: Taking over console
[    0.217037] iommu: Default domain type: Translated
[    0.217049] iommu: DMA domain TLB invalidation policy: strict mode
[    0.222012] SCSI subsystem initialized
[    0.222141] libata version 3.00 loaded.
[    0.222292] usbcore: registered new interface driver usbfs
[    0.222346] usbcore: registered new interface driver hub
[    0.222380] usbcore: registered new device driver usb
[    0.222437] pps_core: LinuxPPS API ver. 1 registered
[    0.222446] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    0.222464] PTP clock support registered
[    0.222505] EDAC MC: Ver: 3.0.0
[    0.223663] NetLabel: Initializing
[    0.223674] NetLabel:  domain hash size = 128
[    0.223683] NetLabel:  protocols = UNLABELED CIPSOv4 CALIPSO
[    0.223747] NetLabel:  unlabeled traffic allowed by default
[    0.223939] mctp: management component transport protocol core
[    0.223950] NET: Registered PF_MCTP protocol family
[    0.224093] vgaarb: loaded
[    0.225132] clocksource: Switched to clocksource riscv_clocksource
[    0.227480] VFS: Disk quotas dquot_6.6.0
[    0.227609] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[    0.228280] AppArmor: AppArmor Filesystem Enabled
[    0.235515] NET: Registered PF_INET protocol family
[    0.235844] IP idents hash table entries: 262144 (order: 9, 2097152 bytes, linear)
[    0.247714] tcp_listen_portaddr_hash hash table entries: 16384 (order: 6, 262144 bytes, linear)
[    0.247847] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear)
[    0.247916] TCP established hash table entries: 262144 (order: 9, 2097152 bytes, linear)
[    0.248747] TCP bind hash table entries: 65536 (order: 9, 2097152 bytes, linear)
[    0.249729] TCP: Hash tables configured (established 262144 bind 65536)
[    0.250268] MPTCP token hash table entries: 32768 (order: 7, 786432 bytes, linear)
[    0.250526] UDP hash table entries: 16384 (order: 8, 1048576 bytes, linear)
[    0.250893] UDP-Lite hash table entries: 16384 (order: 8, 1048576 bytes, linear)
[    0.251569] NET: Registered PF_UNIX/PF_LOCAL protocol family
[    0.251629] NET: Registered PF_XDP protocol family
[    0.251647] PCI: CLS 0 bytes, default 64
[    0.251732] kvm [1]: hypervisor extension available
[    0.251743] kvm [1]: using Sv48x4 G-stage page table format
[    0.251752] kvm [1]: VMID 0 bits available
[    0.251809] Trying to unpack rootfs image as initramfs...
[    0.258604] Initialise system trusted keyrings
[    0.258682] Key type blacklist registered
[    0.258828] workingset: timestamp_bits=46 max_order=23 bucket_order=0
[    0.267004] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[    0.269857] fuse: init (API version 7.44)
[    0.270563] integrity: Platform Keyring initialized
[    0.270608] integrity: Machine keyring initialized
[    0.323429] Key type asymmetric registered
[    0.323448] Asymmetric key parser 'x509' registered
[    0.323677] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 243)
[    0.323870] io scheduler mq-deadline registered
[    0.325660] riscv-plic: interrupt-controller@c000000: mapped 520 interrupts with 4 handlers for 8 contexts.
[    0.327067] ledtrig-cpu: registered to indicate activity on CPUs
[    0.327990] eswin-pcie 54000000.pcie: host bridge /soc/pcie@0x54000000 ranges:
[    0.328028] eswin-pcie 54000000.pcie:       IO 0x0040800000..0x0040ffffff -> 0x0040800000
[    0.328056] eswin-pcie 54000000.pcie:      MEM 0x0041000000..0x004fffffff -> 0x0041000000
[    0.328076] eswin-pcie 54000000.pcie:      MEM 0x8000000000..0x81ffffffff -> 0x8000000000
[    0.445317] eswin-pcie 54000000.pcie: iATU: unroll T, 8 ob, 4 ib, align 4K, limit 8G
[    0.472497] Freeing initrd memory: 8004K
[    1.405145] eswin-pcie 54000000.pcie: Phy link never came up
[    1.405950] eswin-pcie 54000000.pcie: PCI host bridge to bus 0000:00
[    1.405969] pci_bus 0000:00: root bus resource [bus 00-ff]
[    1.405983] pci_bus 0000:00: root bus resource [io  0x0000-0x7fffff] (bus address [0x40800000-0x40ffffff])
[    1.405998] pci_bus 0000:00: root bus resource [mem 0x41000000-0x4fffffff]
[    1.406010] pci_bus 0000:00: root bus resource [mem 0x8000000000-0x81ffffffff pref]
[    1.406059] pci 0000:00:00.0: [1fe1:2030] type 01 class 0x060400 PCIe Root Port
[    1.406085] pci 0000:00:00.0: BAR 0 [mem 0x00000000-0x07ffffff]
[    1.406097] pci 0000:00:00.0: BAR 1 [mem 0x00000000-0x000fffff]
[    1.406109] pci 0000:00:00.0: PCI bridge to [bus 01-ff]
[    1.406123] pci 0000:00:00.0:   bridge window [io  0x0000-0x0fff]
[    1.406135] pci 0000:00:00.0:   bridge window [mem 0x00000000-0x000fffff]
[    1.406150] pci 0000:00:00.0:   bridge window [mem 0x00000000-0x000fffff 64bit pref]
[    1.406209] pci 0000:00:00.0: supports D1 D2
[    1.406219] pci 0000:00:00.0: PME# supported from D0 D1 D3hot
[    1.409036] pci_bus 0000:01: busn_res: [bus 01-ff] end is updated to 01
[    1.409066] pci 0000:00:00.0: BAR 0 [mem 0x48000000-0x4fffffff]: assigned
[    1.409081] pci 0000:00:00.0: BAR 1 [mem 0x41000000-0x410fffff]: assigned
[    1.409096] pci 0000:00:00.0: PCI bridge to [bus 01]
[    1.409110] pci_bus 0000:00: resource 4 [io  0x0000-0x7fffff]
[    1.409121] pci_bus 0000:00: resource 5 [mem 0x41000000-0x4fffffff]
[    1.409151] pci_bus 0000:00: resource 6 [mem 0x8000000000-0x81ffffffff pref]
[    1.410872] pcieport 0000:00:00.0: PME: Signaling with IRQ 14
[    1.411107] pcieport 0000:00:00.0: AER: enabled with IRQ 14
[    1.412540] Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled
[    1.414053] printk: legacy console [ttyS0] disabled
[    1.434363] 50900000.serial: ttyS0 at MMIO 0x50900000 (irq = 15, base_baud = 12500000) is a 16550A
[    1.434402] printk: legacy console [ttyS0] enabled
[    3.036328] 50910000.serial: ttyS1 at MMIO 0x50910000 (irq = 16, base_baud = 12500000) is a 16550A
[    3.065932] 50920000.serial: ttyS2 at MMIO 0x50920000 (irq = 17, base_baud = 12500000) is a 16550A
[    3.081722] loop: module loaded
[    3.085271] SCSI Media Changer driver v0.25
[    3.090185] tun: Universal TUN/TAP device driver, 1.6
[    3.095395] PPP generic driver version 2.4.2
[    3.102018] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
[    3.107548] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 1
[    3.115765] xhci-hcd xhci-hcd.0.auto: hcc params 0x0220fe45 hci version 0x110 quirks 0x0000808000000010
[    3.125170] xhci-hcd xhci-hcd.0.auto: irq 18, io mem 0x50480000
[    3.131213] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
[    3.136686] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 2
[    3.144324] xhci-hcd xhci-hcd.0.auto: Host supports USB 3.0 SuperSpeed
[    3.151070] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 6.16
[    3.159324] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    3.166535] usb usb1: Product: xHCI Host Controller
[    3.171388] usb usb1: Manufacturer: Linux 6.16.0 xhci-hcd
[    3.176769] usb usb1: SerialNumber: xhci-hcd.0.auto
[    3.181988] hub 1-0:1.0: USB hub found
[    3.185760] hub 1-0:1.0: 1 port detected
[    3.190011] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM.
[    3.198198] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 6.16
[    3.206446] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    3.213653] usb usb2: Product: xHCI Host Controller
[    3.218507] usb usb2: Manufacturer: Linux 6.16.0 xhci-hcd
[    3.223890] usb usb2: SerialNumber: xhci-hcd.0.auto
[    3.229196] hub 2-0:1.0: USB hub found
[    3.232966] hub 2-0:1.0: 1 port detected
[    3.237346] usbcore: registered new interface driver uas
[    3.242688] usbcore: registered new interface driver usb-storage
[    3.248696] usbcore: registered new interface driver ums-alauda
[    3.254625] usbcore: registered new interface driver ums-cypress
[    3.260636] usbcore: registered new interface driver ums-datafab
[    3.266650] usbcore: registered new interface driver ums_eneub6250
[    3.272834] usbcore: registered new interface driver ums-freecom
[    3.278854] usbcore: registered new interface driver ums-isd200
[    3.284780] usbcore: registered new interface driver ums-jumpshot
[    3.290891] usbcore: registered new interface driver ums-karma
[    3.296744] usbcore: registered new interface driver ums-onetouch
[    3.302839] usbcore: registered new interface driver ums-realtek
[    3.308853] usbcore: registered new interface driver ums-sddr09
[    3.314786] usbcore: registered new interface driver ums-sddr55
[    3.320710] usbcore: registered new interface driver ums-usbat
[    3.326753] mousedev: PS/2 mouse device common for all mice
[    3.332986] eswin-rtc 51818000.rtc: registered as rtc0
[    3.338120] eswin-rtc 51818000.rtc: setting system clock to 1970-01-01T00:00:00 UTC (0)
[    3.346269] i2c_dev: i2c /dev entries driver
[    3.350868] eswin_fan_control_driver 50b50000.fan_control: state.period: 100000 state.duty_cycle: 99609
[    3.360348] eswin_fan_control_driver 50b50000.fan_control: eswin fan control init done
[    3.369698] hwmon hwmon1: temp1_input not attached to any thermal zone
[    3.377366] hwmon hwmon2: temp1_input not attached to any thermal zone
[    3.383939] device-mapper: core: CONFIG_IMA_DISABLE_HTABLE is disabled. Duplicate IMA measurements will not be recorded in the IMA log.
[    3.396215] device-mapper: uevent: version 1.0.3
[    3.401033] device-mapper: ioctl: 4.50.0-ioctl (2025-04-28) initialised: dm-devel@lists.linux.dev
[    3.410004] EDAC DEVICE0: Giving out device to module Sifive ECC Manager controller sifive_edac.0: DEV sifive_edac.0 (INTERRUPT)
[    3.423360] sdhci: Secure Digital Host Controller Interface driver
[    3.429496] sdhci: Copyright(c) Pierre Ossman
[    3.433835] sdhci-pltfm: SDHCI platform and OF driver helper
[    3.439780] riscv-pmu-sbi: SBI PMU extension is available
[    3.445149] riscv-pmu-sbi: 15 firmware and 6 hardware counters
[    3.452313] drop_monitor: Initializing network drop monitor service
[    3.459427] NET: Registered PF_INET6 protocol family
[    3.476770] Segment Routing with IPv6
[    3.480428] In-situ OAM (IOAM) with IPv6
[    3.484348] NET: Registered PF_PACKET protocol family
[    3.489445] Key type dns_resolver registered
[    3.493292] mmc0: SDHCI controller on 50450000.mmc [50450000.mmc] using ADMA 64-bit
[    3.498498] registered taskstats version 1
[    3.505764] Loading compiled-in X.509 certificates
[    3.511671] Loaded X.509 cert 'Build time autogenerated kernel key: 6fe0ad397311d20a83c85ba96cb93b486769aa07'
[    3.535265] Key type .fscrypt registered
[    3.539147] Key type fscrypt-provisioning registered
[    3.566432] Key type encrypted registered
[    3.570408] AppArmor: AppArmor sha256 policy hashing enabled
[    3.576081] ima: No TPM chip found, activating TPM-bypass!
[    3.581519] Loading compiled-in module X.509 certificates
[    3.587957] Loaded X.509 cert 'Build time autogenerated kernel key: 6fe0ad397311d20a83c85ba96cb93b486769aa07'
[    3.597821] ima: Allocated hash algorithm: sha256
[    3.602531] ima: No architecture policies found
[    3.607053] evm: Initialising EVM extended attributes:
[    3.612139] evm: security.selinux
[    3.615436] evm: security.SMACK64
[    3.618735] evm: security.SMACK64EXEC
[    3.622380] evm: security.SMACK64TRANSMUTE
[    3.626460] evm: security.SMACK64MMAP
[    3.630106] evm: security.apparmor
[    3.633491] evm: security.ima
[    3.636438] evm: security.capability
[    3.640001] evm: HMAC attrs: 0x1
[    3.661765] clk: Not disabling unused clocks
[    3.692521] mmc0: Failed to initialize a non-removable card
[    3.704519] mmc2: SDHCI controller on 50470000.mmc [50470000.mmc] using ADMA 64-bit
[    3.704965] mmc1: SDHCI controller on 50460000.mmc [50460000.mmc] using ADMA 64-bit
[    3.726637] Freeing unused kernel image (initmem) memory: 6240K
[    3.738152] Checked W+X mappings: passed, no W+X pages found
[    3.743772] Run /init as init process
[    3.747404]   with arguments:
[    3.750360]     /init
[    3.752606]   with environment:
[    3.755736]     HOME=/
[    3.758085]     TERM=linux
[    3.772359] udevd[110]: starting version 3.2.14
[    3.824587] mmc1: new UHS-I speed SDR104 SDXC card at address 5048
[    3.831222] mmcblk1: mmc1:5048 SD64G 58.0 GiB
[    3.839598]  mmcblk1: p1 p2
[    3.885608] mmc2: Failed to initialize a non-removable card
[    9.581139] random: crng init done
[    9.593654] udevd[112]: starting eudev-3.2.14
[    9.599855] udevd[117]: failed to execute '/usr/sbin/nfsrahead' '/usr/sbin/nfsrahead 179:0': No such file or directory
[    9.786809] EXT4-fs (mmcblk1p2): mounted filesystem 32539e08-a5c0-4084-9f32-0932043d95e3 ro without journal. Quota mode: none.
[    9.873135] raid6: int64x8  gen()  2106 MB/s
[    9.945128] raid6: int64x4  gen()  3061 MB/s
[   10.017129] raid6: int64x2  gen()  3150 MB/s
[   10.089131] raid6: int64x1  gen()  2732 MB/s
[   10.093345] raid6: using algorithm int64x2 gen() 3150 MB/s
[   10.165132] raid6: .... xor() 1675 MB/s, rmw enabled
[   10.170041] raid6: using intx1 recovery algorithm
[   10.179518] xor: measuring software checksum speed
[   10.184848]    8regs           :  5776 MB/sec
[   10.189712]    32regs          :  5858 MB/sec
[   10.194013] xor: using function: 32regs (5858 MB/sec)
[   10.332457] Btrfs loaded, zoned=yes, fsverity=yes
[   10.510595] SGI XFS with ACLs, security attributes, realtime, quota, no debug enabled
[   13.789388] platform soc:usb1@50490000: deferred probe pending: platform: wait for supplier /soc/gpio@51600000/gpio-port@1
[   14.738556] udevd[171]: starting version 3.2.14
[   14.771695] udevd[171]: specified group 'netdev' unknown
[   14.779458] udevd[172]: starting eudev-3.2.14
[   14.906303] dw_axi_dmac_platform 50430000.dma-controller-hsp: probe with driver dw_axi_dmac_platform failed with error -2
[   14.919597] dw_axi_dmac_platform 518c0000.dma-controller-aon: probe with driver dw_axi_dmac_platform failed with error -2
[   14.941690] xhci-hcd xhci-hcd.2.auto: xHCI Host Controller
[   14.947166] xhci-hcd xhci-hcd.2.auto: new USB bus registered, assigned bus number 3
[   14.955332] xhci-hcd xhci-hcd.2.auto: hcc params 0x0220fe45 hci version 0x110 quirks 0x0000808000000010
[   14.964822] xhci-hcd xhci-hcd.2.auto: irq 63, io mem 0x50490000
[   14.970881] xhci-hcd xhci-hcd.2.auto: xHCI Host Controller
[   14.976376] xhci-hcd xhci-hcd.2.auto: new USB bus registered, assigned bus number 4
[   14.981057] eic7700-eth-dwmac 50400000.ethernet: Deprecated MDIO bus assumption used
[   14.984001] xhci-hcd xhci-hcd.2.auto: Host supports USB 3.0 SuperSpeed
[   14.984020] OF: /soc/ethernet@50400000/stmmac-axi-config: Read of boolean property 'snps,lpi_en' with a value.
[   14.991806] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 6.16
[   14.998244] eic7700-eth-dwmac 50400000.ethernet: PTP uses main clock
[   15.008195] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[   15.008200] usb usb3: Product: xHCI Host Controller
[   15.008203] usb usb3: Manufacturer: Linux 6.16.0 xhci-hcd
[   15.008507] eic7700-eth-dwmac 50400000.ethernet: User ID: 0x10, Synopsys ID: 0x52
[   15.010595] eswin-bootspi 51800000.spi: ssi_max_xfer_size=32
[   15.011080] spi-nor spi0.0: supply vcc not found, using dummy regulator
[   15.016442] usb usb3: SerialNumber: xhci-hcd.2.auto
[   15.016766] hub 3-0:1.0: USB hub found
[   15.022792] eic7700-eth-dwmac 50400000.ethernet:     DWMAC4/5
[   15.029999] hub 3-0:1.0: 1 port detected
[   15.034856] eic7700-eth-dwmac 50400000.ethernet: DMA HW capability register supported
[   15.041135] usb usb4: We don't know the algorithms for LPM for this host, disabling LPM.
[   15.047696] eic7700-eth-dwmac 50400000.ethernet: RX Checksum Offload Engine supported
[   15.053399] usb usb4: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 6.16
[   15.059943] eic7700-eth-dwmac 50400000.ethernet: TX Checksum insertion supported
[   15.064788] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[   15.064793] usb usb4: Product: xHCI Host Controller
[   15.064801] eic7700-eth-dwmac 50400000.ethernet: Enable RX Mitigation via HW Watchdog Timer
[   15.064807] usb usb4: Manufacturer: Linux 6.16.0 xhci-hcd
[   15.064816] eic7700-eth-dwmac 50400000.ethernet: Enabled L3L4 Flow TC (entries=4)
[   15.064821] usb usb4: SerialNumber: xhci-hcd.2.auto
[   15.064829] eic7700-eth-dwmac 50400000.ethernet: Enabled RFS Flow TC (entries=10)
[   15.065211] hub 4-0:1.0: USB hub found
[   15.068530] eic7700-eth-dwmac 50400000.ethernet: Using 48/48 bits DMA host/device width
[   15.074009] hub 4-0:1.0: 1 port detected
[   15.100130] eswin-bootspi 51800000.spi: fifo_len 256, polling mode.
[   15.293220] usb 3-1: new high-speed USB device number 2 using xhci-hcd
[   15.323029] YT8531 Gigabit Ethernet stmmac-0:00: attached PHY driver (mii_bus:phy_addr=stmmac-0:00, irq=POLL)
[   15.332901] YT8531 Gigabit Ethernet stmmac-0:01: attached PHY driver (mii_bus:phy_addr=stmmac-0:01, irq=POLL)
[   15.343688] eic7700-eth-dwmac 50410000.ethernet: Deprecated MDIO bus assumption used
[   15.351420] OF: /soc/ethernet@50410000/stmmac-axi-config: Read of boolean property 'snps,lpi_en' with a value.
[   15.361401] eic7700-eth-dwmac 50410000.ethernet: PTP uses main clock
[   15.367937] eic7700-eth-dwmac 50410000.ethernet: User ID: 0x10, Synopsys ID: 0x52
[   15.375378] eic7700-eth-dwmac 50410000.ethernet:     DWMAC4/5
[   15.380838] eic7700-eth-dwmac 50410000.ethernet: DMA HW capability register supported
[   15.388653] eic7700-eth-dwmac 50410000.ethernet: RX Checksum Offload Engine supported
[   15.396462] eic7700-eth-dwmac 50410000.ethernet: TX Checksum insertion supported
[   15.403839] eic7700-eth-dwmac 50410000.ethernet: Enable RX Mitigation via HW Watchdog Timer
[   15.412177] eic7700-eth-dwmac 50410000.ethernet: device MAC address 3a:4e:29:88:e8:30
[   15.419988] eic7700-eth-dwmac 50410000.ethernet: Enabled L3L4 Flow TC (entries=4)
[   15.427449] eic7700-eth-dwmac 50410000.ethernet: Enabled RFS Flow TC (entries=10)
[   15.434916] eic7700-eth-dwmac 50410000.ethernet: Using 48/48 bits DMA host/device width
[   15.435975] usb 3-1: New USB device found, idVendor=05e3, idProduct=0608, bcdDevice=85.36
[   15.451059] usb 3-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[   15.458177] usb 3-1: Product: USB2.0 Hub
[   15.503950] hub 3-1:1.0: USB hub found
[   15.507895] hub 3-1:1.0: 4 ports detected
[   15.668532] YT8531 Gigabit Ethernet stmmac-1:00: attached PHY driver (mii_bus:phy_addr=stmmac-1:00, irq=POLL)
[   15.678403] YT8531 Gigabit Ethernet stmmac-1:01: attached PHY driver (mii_bus:phy_addr=stmmac-1:01, irq=POLL)
[   15.729807] EXT4-fs: Remounting file system with no journal so ignoring journalled data option
[   15.758946] EXT4-fs (mmcblk1p2): re-mounted 32539e08-a5c0-4084-9f32-0932043d95e3 r/w.
[   15.793672] EXT4-fs (mmcblk1p1): mounted filesystem 5c205338-1b02-4bc9-a396-dc0fe556357f r/w with ordered data mode. Quota mode: none.
[   15.815971] Adding 131068k swap on /swap.  Priority:5 extents:2 across:52174848k SS
irradium  (starpro64) (ttyS0)
starpro64 login:
donation   irradium
performance testing on lichee pi 4a T-Head th1520 and banana pi f3 SpacemiT k1, mesa package compilation:
time prt-get update mesa
prt-get: updated successfully
real    65m2.670s
user    231m38.567s
sys    14m14.824s
real    48m32.365s
user    342m27.137s
sys    14m44.450s
visionfive 2 JH7110
real    69m52.519s
user    248m33.483s
sys    11m3.013s
StarPro64 EIC7700X
real 42m27.966s
user 154m0.664s
sys 8m11.515s
donation   irradium
kernel 6.6.101
irradium-3.8-riscv64-core-starpro64-6.6.101-build-20250807.img.zst
irradium-3.8-riscv64-core-starpro64-6.6.101-build-20250807.img.zst.sha256
irradium-3.8-riscv64-xfce-starpro64-6.6.101-build-20250807.img.zst
irradium-3.8-riscv64-xfce-starpro64-6.6.101-build-20250807.img.zst.sha256
donation   irradium
kernel 6.6.103
mirror 1, mirror 2, mirror 3, mirror 4, mirror 5
irradium-3.8-riscv64-core-starpro64-6.6.103-build-20250830.img.zst
irradium-3.8-riscv64-core-starpro64-6.6.103-build-20250830.img.zst.sha256
irradium-3.8-riscv64-xfce-starpro64-6.6.103-build-20250830.img.zst
irradium-3.8-riscv64-xfce-starpro64-6.6.103-build-20250830.img.zst.sha256
donation   irradium
kernel 6.6.106
irradium-3.8-riscv64-core-starpro64-6.6.106-build-20250913.img.zst
irradium-3.8-riscv64-core-starpro64-6.6.106-build-20250913.img.zst.sha256
irradium-3.8-riscv64-xfce-starpro64-6.6.106-build-20250913.img.zst
irradium-3.8-riscv64-xfce-starpro64-6.6.106-build-20250913.img.zst.sha256
donation   irradium
Is a version of this going to be provided for the Star64?
She is in
donation   irradium
  Star64 Irradium (based on crux linux) riscv64, aarch64 mara 19 17,788 05-12-2026, 08:17 AM
Last Post: tantamount
  Running Linux on Pinebook Pro with External Monitor Twers1962 2 2,941 03-25-2025, 11:10 PM
Last Post: Dendrocalamus64
  linux-headers and quartz64-post-install package conflicts Berzerkleyfan 2 4,336 12-01-2023, 05:17 AM
Last Post: Berzerkleyfan
  Star64 JH7110 (slarm64, riscv64) mara 2 4,632 10-09-2023, 03:43 AM
  qemu-system-aarch64 11b2p508 1 5,181 07-19-2018, 10:26 PM
Last Post: shizzle411
  Linux Headers jedichewbacca 5 13,452 02-28-2018, 10:35 PM
Last Post: evilbunny
Information Installing Node.js from source on Arch Linux faddah 1 12,195 09-15-2017, 06:45 AM
Last Post: carlonsins
  Mini-Tutorial to get a linux Desktop GUI working on Pine64+ speedro86 15 37,721 04-05-2017, 01:45 PM
Last Post: speedro86
  Linux laptop rusty377 2 6,901 11-27-2016, 08:52 PM
Last Post: pfeerick
  why are there different images based on sd card size? checktravis 2 7,373 07-28-2016, 08:41 AM
Last Post: xalius
