Cannot make calls
Sim card network is registered i cannot make calls modem is enabled
maybe you should try those basics first. update pmos to the latest packages.
i think tha commands were:
$ sudo apk update $ sudo apk upgrade ## then reboot
(03-24-2025, 01:13 PM)neithan76 Wrote: Sim card network is registered i cannot make calls modem is enabled
As above check you are updated. Also, during boot is the modem found (especially at about 45 seconds)?
pmos:~$ sudo dmesg | grep "usb 2-1" .... [  45.632360] usb 2-1: new high-speed USB device number 3 using ehci-platform [  45.792522] usb 2-1: New USB device found, idVendor=2c7c, idProduct=0125, bcdDevice= 3.18 [  45.792567] usb 2-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3 [  45.792583] usb 2-1: Product: LTE Module [  45.792591] usb 2-1: Manufacturer: Quectel, Incorporated [  45.792605] usb 2-1: SerialNumber: community_fw [  45.869827] usb 2-1: GSM modem (1-port) converter now attached to ttyUSB0 [  45.871254] usb 2-1: GSM modem (1-port) converter now attached to ttyUSB1 [  45.873156] usb 2-1: GSM modem (1-port) converter now attached to ttyUSB2 [  45.874451] usb 2-1: GSM modem (1-port) converter now attached to ttyUSB3
And registering - what is output from Modem, Modem Info menu option? You should see IMEI, Operator details etc?
I'm assuming that you changed from Manjaro, because the pphone crashed after making calls.
I am having no problem making and receiving calls, using PostmarketOS, however after not using the pphone for a few hours, the modem disappears and I have to reboot.
I installed the software at The Modem Distro but that seems to have made no difference but maybe it would in your case?
 (I'm intrigued that @dukla2000 uses his as a daily driver. I would like to be able to do that.)
PinePhone Beta 2GB/16GB Arch Linux ARM danctnix from3 Oct 2025
(was Postmarket OS v24.12)
PineTab2 Arch Danctnix 6.4.2
  Cannot send or receive calls insidetrip101 2 4,846 11-04-2022, 06:47 PM
Last Post: mob
  Calls don't work on Softbank. Cellular data & SMS work. yasmi 1 3,844 03-24-2022, 04:10 AM
Last Post: yasmi
  sxmo image Verizon calls and SMS work! Saliency 8 15,520 08-22-2020, 03:28 AM
Last Post: PureTryOut
  How to make volume and power buttons do things koampapapa 3 8,841 07-31-2020, 12:49 PM
Last Post: Boern
  Making Calls Zweitaktmotor 11 24,593 07-19-2020, 04:59 AM
