On-Screen Keyboard Arrow Keys
With the current Phosh the included on-screen terminal keyboard has changed and while most of the improvements are great where is my unix up-key?
I like to up/down to scroll for my previous inputs. Also what is the left/righ arrow key next to A?
(03-04-2025, 03:35 PM)biketool Wrote: With the current Phosh the included on-screen terminal keyboard has changed and while most of the improvements are great where is my unix up-key?
With phosh and squeekboard, just create your own layout. Here is mine.
https://github.com/mikeshenson/Phosh-Squ...d-Keyboard
sudo apt install squeekeyboard... installs...(not sure this does anything for phosh)
go to the git..
mkdir ~/.local/share/squeekboard/keyboards/
mkdit ~/.local/share/squeekboard/keyboards/number/
mkdir ~/.local/share/squeekboard/keyboards/terminal/
wget the
https://github.com/mikeshenson/Phosh-Squeekboard-Keyboard/blob/main/us.yaml
https://github.com/mikeshenson/Phosh-Squeekboard-Keyboard/blob/main/terminal/us.yaml
https://github.com/mikeshenson/Phosh-Squeekboard-Keyboard/blob/main/number/us.yaml
into the appropriate dirs
reboot...  ???
what am I missing, i dont want the wide only your US yaml
(03-10-2025, 03:50 AM)biketool Wrote: what am I missing, i dont want the wide only your US yaml
It is hard for me to understand this sentence.
Do you want the wide keyboard?
If so, wget the wide layouts
wget https://github.com/mikeshenson/Phosh-Squeekboard-Keyboard/blob/main/us_wide.yaml
wget https://github.com/mikeshenson/Phosh-Squeekboard-Keyboard/blob/main/terminal/us_wide.yaml
wget https://github.com/mikeshenson/Phosh-Squeekboard-Keyboard/blob/main/number/us_wide.yaml
Sorry IDK... Brain damage? spaced out between edits?
What I had meant to say was I want only the non-wide keyboard
not sure what I was missing, all files/dirs are in place as specified
and I see what I did in in the post error some cut/paste form the git
in my Pphone I have the non-wide us.yaml wget'ed from the proper places in the git like this
~/.local/share/squeekboard/keyboards/us.yaml
~/.local/share/squeekboard/keyboards/number/us.yaml
~/.local/share/squeekboard/keyboards/terminal/us.yaml
there was a keyboard with arrows but i don't remember which one
i'll try to check tomorow
ezik
(03-10-2025, 08:46 AM)biketool Wrote: I see what I did in in the post error some cut/paste form the git
Are you all set now?
Also, open the local us.yml and look for "M4". I have include M1 through M12. You can change the label and text to what ever you want.
Find:
M4:
        outline: "small"
        text: "M4"
        label: "M4"
replace with:
M4:
        outline: "small"
        text: "youremail@gmail.com"
        label: "GMAI"
A community member recently contributed alternative layouts optimized for different use cases..
https://forum.pine64.org/showthread.php?tid=19619
http://loopgain.net/pinephone/
Find:
M4:
        outline: "small"
        text: "M4"
        label: "M4"
replace with:
M4:
        outline: "small"
        label: "GMAI"
I will give this a try when I have time, so far no new keyboard, I searched in both mobile touch keyboard and in the regular settings keyboard settings.
I have been been taking half days sick so probably made mistakes though I checked the above and the files and dirs are all correct, what else is required to activate the non-wide kb?
It really makes me remember how much a terminal user relies on tab and arrow keys having to type EVERYTHING out EVERY time!
I felt like the old layouts were pretty good for a cramped phone touch interface, no idea why they changed it.
Hi.
I made squeekboard/keyboards/terminal folders as recommended, using Portfolio. Then I copied the us.yaml file to the
folder, and this is also possible using Portfolio. There was a situation that it didn't work. I realized that you need to uninstall Addon Phosh OSK via the software app.
Finally, it is necessary to log out the user or restart the system.
This is seen in the attached pictures, you can try the same.
  Trixie - bring up the On Screen Keyboard manually. grump_fiddle_reinstall 0 321 12-23-2025, 04:34 AM
  How to add an homemade app to the main screen? JChdeL 3 728 11-04-2025, 04:13 AM
Last Post: JChdeL
  New Install, apps start but don't show up on screen?! RT3 2 2,186 07-18-2025, 07:56 PM
  mobian phosh on screen keyboard not popping up for Chromium/Electron apps grump_fiddle_reinstall 1 3,381 01-15-2025, 08:08 PM
  icon keyboard chris_02 4 4,647 01-14-2025, 02:49 AM
  New keyboard issue sandspur 30 33,418 01-13-2025, 01:37 AM
  Proximity sensor is oversensitive (was "Screen blanks when making call") treebeard 6 8,318 08-05-2024, 06:12 AM
Last Post: baptx
  Keyboard not popping up on QT apps 3x5co 1 2,604 02-08-2024, 11:45 PM
  Screen auto-rotation sensitivity mdk 0 1,920 12-26-2023, 06:08 AM
Last Post: mdk
  Keyboard keeps disappearing the moment it's touched jojuma 1 2,368 10-29-2023, 08:34 AM
Last Post: walter1950
