New PinePhone Pro. No sudo command or access to root password.
I recently purchased a new PinePhone Pro and I'm working on getting everything working with my carrier, but I've found that the sudo command appears to be missing entirely and I don't know if there's a default root password set on these when shipped new. I tried the recovery mode process by shutting the phone completely off then holding power and volume up, but the phone will not even turn on when doing this. I'm a Linux professional and I know my way around in bash rather well, but I need to get past this initial hurdle before I can do much of anything.
Unlike Android, there is no recovery, just a simpler more desktop-like bootloader and you boot into whatever you want (SD card or eMMC). I think by default you get SailfishOS which I'm not familiar with, but see this for "sudo" info: https://www.reddit.com/r/sailfishos/comm..._terminal/
There are LOTS of other distros to try: https://wiki.pine64.org/wiki/PinePhone_P...e_Releases
(02-27-2025, 12:38 AM)DanNewman Wrote: I recently purchased a new PinePhone Pro and I'm working on getting everything working with my carrier, but I've found that the sudo command appears to be missing entirely and I don't know if there's a default root password set on these when shipped new.
Dan,
This phone can be a lot of fun! I learned a lot setting mine up. Find a distro that you know the best and go with it!
I use Arch Linux on EVERYTHING, so... I think Arch works well.
See this post for a complete install and setup.
https://forum.pine64.org/showthread.php?tid=18192
See this post for my experience on functionally
https://forum.pine64.org/showthread.php?...#pid118783
See this post for how I got Calls working on my PinePhonePro.
https://forum.pine64.org/showthread.php?tid=19428
2023 May through today my daily driver is a PinePhonePro running DanctNIX Arch with Phosh
2021 May through 2023 May my daily driver was a PinePhone running DanctNIX Arch with Phosh
I am running DanctNIX Arch with Phosh on a PinePhonePro and I have not had any of the issues people keep talking about. Calls, VoLTE, SMS, MMS, cell broadcast messages, voice mail, internet, Wifi, 4G data, mobile hot spot, calendar, calendar notifications, contacts, syncthing, Navigation with GPS and offline maps via osmin work, connecting Google accounts work, Groupme via firefox, Facebook via firefox ALL WORK. Calls, SMS, MMS all work from sleep.
I have not tested alarms from sleep. I have not tested any bluetooth items. The camera somewhat works with compiling my own packages. I currently use an Android device to take pictures and syncthing puts them on the PinePhonePro.
Device: PinePhone 32Gig (Used for building packages)
Device: PinePhonePro (Daily driver)
OS: DanctNIX Arch with Phosh
Carrier: USA - Patriot Mobile (T-Mobile SIM)
EG25 Firmware: Biktorgj 0.8.0
ADSP Version: 01.003
(02-27-2025, 06:01 AM)teekay Wrote: Unlike Android, there is no recovery, just a simpler more desktop-like bootloader and you boot into whatever you want (SD card or eMMC). I think by default you get SailfishOS which I'm not familiar with, but see this for "sudo" info: https://www.reddit.com/r/sailfishos/comm..._terminal/
Got it now. The devel-su command was what I was looking for. I have SMS and voice working with a Verizon SIM, but so far no luck getting mobile data working. Verizon support tried activating it on their end, but they are getting an error message back that the device isn't compatible. I'll keep at it though. I know there is a app in development for MMS, but I forgot what it was called. Thanks!
I can only second the recommendation to replace the shipped Sailfish OS with a standard GNU/Linux distribution that is actually Free Software and that will have sudo working out of the box. Either postmarketOS, or Mobian, or DanctNIX (Arch Linux ARM). With Plasma Mobile or Phosh as your graphical environment. (Note that postmarketOS now uses doas as its default sudo implementation, but it can be invoked as sudo, so you will probably not notice the difference.)
  "USB access to SD" disappeared on a Pinephone Pro jebez 0 817 06-19-2026, 06:40 PM
Last Post: jebez
  what stopped pinephone pro? heocb 1 1,701 01-14-2026, 09:56 AM
  PinePhone Pro: Camera App very laggy Martin87 3 5,903 08-22-2025, 11:23 PM
Last Post: teekay
  PinePhone Pro discontinued teekay 9 15,930 08-22-2025, 11:19 PM
Last Post: teekay
Exclamation Pinephone Pro wont boot to anything! Supervisor 5 3,861 08-18-2025, 06:15 PM
  Pinephone pro ee bricked? dennylee 3 2,970 07-22-2025, 12:06 AM
Last Post: Dendrocalamus64
  Full desktop Surfing and Absolute Privacy on the pinephone? Www 8 5,071 06-30-2025, 10:51 AM
  Backing up data on Pinephone Pro to hard disk, optical disk and flash? Www 4 3,542 06-29-2025, 02:46 PM
  Printing and scanning documents with pinephone? Www 4 3,579 06-29-2025, 11:48 AM
  FM? A future new PinePhone? jebez 1 2,412 06-26-2025, 11:47 AM
Last Post: zetabeta
