Default Debian Trixie entry from /etc/apt/sources.list
Question
getHello,
I just received my Community Edition PineNote today Big Grin  I accidentally removed the default Debian Trixie entry from `/etc/apt/sources.list`, and was hoping someone could post theirs for me?
Before I removed the entry, `sudo apt update && sudo apt upgrade` was working correctly and showing 0 new updates available after I did my initial upgrade on the first boot.
After the entry was removed, when I use the standard Debian naming convention for the Trixie sources list I'm getting this error:
Get:1 http://deb.debian.org/debian trixie InRelease [175 kB] Hit:2 http://pinenote.mweigand.net/repo_pn_stable trixie InRelease                    Error: Release file for http://deb.debian.org/debian/dists/trixie/InRelease is expired (invalid since 2d 1h 54min 47s). Updates for this repository will not be applied.
If I point apt to `bookworm` instead of `trixie` I'm able to `update && upgrade`, which shows a number of packages to update indicating I'm currently on a different version (or was, at this point).
The fact that `pnedeb.sources` is pointing to `trixie` tells me I'm not wrong that the factory version that was shipped was also `trixie`, but I'm wondering if I'm just pointing to an incorrect `deb` url...
Could someone please post their `/etc/apt/sources.list` for me? Heart
I've removed my Debian mirror entries from `/etc/apt/sources.list` and I'm able to successfully update/upgrade from `http://pinenote.mweigand.net/repo_pn_stable trixie InRelease`.
As far as I can tell I just need to wait for Debian mirrors to update their Release files, I'm still curious as to what the default `apt` mirror is
If anyone could please post their PineNote's `/etc/apt/sources.list` I would really appreciate it, I am still unable to update my system Sad
Will I be better off just trying to reflash the OS from the PNDeb repo?
(01-22-2025, 09:31 AM)spont Wrote: If anyone could please post their PineNote's `/etc/apt/sources.list` I would really appreciate it, I am still unable to update my system Sad
Attached.
It might also be possible to mount the flash image file as a disk drive on a linux computer and copy any file you like.
.txt   sources.list.txt (Size: 80 bytes / Downloads: 1,659)
.gz   sources.list.tar.gz (Size: 181 bytes / Downloads: 705)
Attached.
Thank you very much!
Attached.
Thank u too!
  base-files_13.6_arm64.deb and wiki.debian.org/UsrMerge vlagged 8 9,155 02-24-2025, 05:44 AM
Last Post: Rorchar
  Debian Trixie Wayland Gnome-Remote-Desktop xfreerdp client bills2002 2 7,186 12-28-2024, 03:38 PM
Last Post: vlagged
