Need OS
I'm looking for the os for the original Pine A64 A64+ I have over and over downloaded the android 8.1
I have also installed on my computer even going back to older systems Phoenix card win 32 disk manager and Etcher
with 7 zip and i can not find an *.IMG for the life of me can some one please tell me what I'm doing wrong or give me a link to the correct software
Please and thank you
I don't know exactly what you're looking for but NetBSD should work fine.
https://nycdn.netbsd.org/pub/arm/
:wq
[ SRA accepts you ]
Everyone wants me to quit using NetBSD
(12-16-2024, 09:58 AM)KC9UDX Wrote: I don't know exactly what you're looking for but NetBSD should work fine.
I'm not sure how to use this do i just flash my SD Card with the Pine64 software on the Net BSD site or do i need to do some thing different?
Thank you for your help
(12-17-2024, 08:18 AM)mtcomp Wrote: I'm not sure how to use this do i just flash my SD Card with the Pine64 software on the Net BSD site or do i need to do some thing different?
you would download this image: https://nycdn.netbsd.org/pub/arm/NetBSD-...e64.img.gz
then use etcher (or similar app, like the Pine64 branded one) to write the img to your SD
there's also several other OS options here: https://pine64.org/documentation/Pine_A64/Software/
If you do decide to go with NetBSD, please do read the guide: https://www.netbsd.org/docs/guide/en/
:wq
[ SRA accepts you ]
(12-17-2024, 11:01 AM)KC9UDX Wrote: If you do decide to go with NetBSD, please do read the guide: https://www.netbsd.org/docs/guide/en/
I down loaded the img file for the pine64 I thought great and when i used etcher it said complete
and i tried in the pine and nope still no boot I have two pines old originals and they will not boot I have the original os android only card i have and they both boot with it but i need a back up os so if this one dies i have the other so Im sot sure what I am doing wrong but im not likening windows 11 im about ready to go back to xp
thank you for the guide
I have also downloaded the android on the pine65 website thats where i started and it dont work either so i am stuck.
Did you download the Android img fro the old wiki or the newer documentation page? The wiki is full of a lot of older/abandoned imgs, such as Android. Try pulling something else from the documentation page I linked above instead.
(12-17-2024, 01:01 PM)tophneal Wrote: Did you download the Android img fro the old wiki or the newer documentation page? The wiki is full of a lot of older/abandoned imgs, such as Android. Try pulling something else from the documentation page I linked above instead.
The link you gave me takes me to the same place where i downloaded the android 8.1 that is all i found i looked for older ones and cant find them.
(12-17-2024, 01:15 PM)mtcomp Wrote: The link you gave me takes me to the same place where i downloaded the android 8.1 that is all i found i looked for older ones and cant find them.
that makes sense then, that android download is not a useable img, it's just the sdk. it will not boot from an sd card. is android your desired img to boot on your A64? if so, those imgs are all very out of date/abandoned. but you can find some here: https://github.com/ayufan-pine64/android...tag/0.3.10
OH There we go I didn't see the Asset Ill try those Thanks I would have never looked there again if you didn't tell me to lol
