atinout binaries for mobian/debian?
Does anyone have any binaries atinout for mobian on pinephone 1.2?
https://atinout.sourceforge.net/ does not have precompiled binaries for debian/mobian and attempting to compile from source results in a segmentation fault error.
(05-12-2024, 10:03 AM)NeutralGrey Wrote: Does anyone have any binaries atinout for mobian on pinephone 1.2?
Download the tar.gz file, and compile on a terminal:
$ gcc atinout.c -o atinout
or
$ gcc -O2 atinout.c -o atinout
If you get an error on line 173, modify this line in this way:
printf("atinout version \" VERSION \"\n");
I compiled it on mobian-bookworm without error, but i did not verify if it works.
I can confirm it works, sending these two commands with success:
echo 'AT+QGMR' | sudo ./atinout - /dev/ttyUSB2 -
echo 'AT+QMBNCFG="list"' | sudo ./atinout - /dev/ttyUSB2 -
There is a Makefile, so you don't need to compile with gcc command directly, you can just type "make" in the source folder.
I got this error:
gcc -o atinout -W -Wall -Wextra -Werror -DVERSION=\"0.9.1\" -g  atinout.c atinout.c: In function ‘is_final_result’: atinout.c:141:20: error: this statement may fall through [-Werror=implicit-fallthrough=]   141 |                if (strcmp(&response[1], "K\r\n") == 0) {       |                    ^ atinout.c:145:9: note: here   145 |        default:       |        ^~~~~~~ cc1: all warnings being treated as errors        make: *** [Makefile:14: atinout] Error 1
So I removed -Werror from the Makefile and it compiled successfully.
If you want to use "atinout" instead of "./atinout" for the commands, you can install the binary with "sudo make install".
Executing AT commands works too:
https://wiki.pine64.org/index.php/PinePhone#AT_commands
It looks like there aren’t any precompiled binaries for Atinout on Mobian for the PinePhone. If you’re facing segmentation faults while compiling from source, it could be related to dependencies or specific configurations for ARM architecture.
Here are a few suggestions you could try:
Check Dependencies: Ensure all required libraries and dependencies are properly installed. Sometimes missing or incompatible versions can lead to segmentation faults.
Debugging: If you’re comfortable, you could try running the compilation with debugging tools like gdb to pinpoint where the segmentation fault occurs.
Community Support: Consider reaching out on forums or community channels related to Mobian or PinePhone. Other users may have encountered similar issues or may have binaries available.
Alternative Solutions: If Atinout is crucial for your use case, you could explore whether similar tools are available or if you could use a different method to achieve your goals.
geometry dash wave
Play geometry dash wave to improve your reflex skills
  Mobian MMS/SMS text problem bcnaz 16 40,053 06-23-2026, 06:53 AM
Last Post: mehdy
  Mobian image for the PinePhone Korfou 2 1,935 04-27-2026, 09:57 AM
Last Post: Korfou
  bookworm vs trixie discussion for mobian in pinephone regular. zetabeta 80 70,709 12-24-2025, 12:11 AM
  cryptocurrency on mobian/pinephone biketool 33 74,608 10-08-2025, 06:21 AM
  XLibre for Mobian Hiraghm 0 3,508 06-29-2025, 12:38 PM
Last Post: Hiraghm
  Axolotl on PinePhone / Mobian arno_nuehm 223 351,929 06-25-2025, 01:19 PM
Last Post: anonymous
  VoIP account on mobian dialer j_s 0 3,178 06-15-2025, 04:19 PM
Last Post: j_s
  Mobian Pinephone Notification LED biketool 2 4,398 06-07-2025, 03:19 PM
  Vivaldi Web browser nearly native for Mobian biketool 3 5,156 05-06-2025, 02:19 AM
  mobian calamares fail merom 2 4,840 04-29-2025, 02:10 PM
Last Post: mdk
