Supported Carrier and Modem Bands
Is there a somewhere I can find out what carriers will fully support PinePhone for all of data, voice and text (not just one or the other)? AT&T and Verizon only support voice and calls but no data.
I found the following on the PinePhone page but I am no cellular export such that I can translate this into whether it is supported or not.
Communication:
Modem: Quectel EG25-G
LTE-FDD: B1, B2, B3, B4, B5, B7, B8, B12, B13, B18, B19, B20, B25, B26, B28
LTE-TDD: B38, B39, B40, B41
GSM: B2, B3, B5, B8 (850, 900, 1800, 1900 MHz)
Bluetooth: 4.0, A2DP
thank you
There is https://wiki.pine64.org/wiki/PinePhone_Carrier_Support. It is not necessarily complete, but it is the best reference I know of.
Not helped by some carriers making arbitrary decisions to block devices that are otherwise capable of working. This has also been seen at the SIM level, so different SIMs from the same carrier may or may not work depending on a setting in the carrier's backend systems.
when I tried to get my pinephone set up with verizon in 2022 they refused. I moved on and found that t-mobile supports it, and I can even get the hotspot going
In the USA, T-Mobile is reportedly the one physical carrier to use, several MVNOs using the T-Mobile network under the hood are also reported to work. (I cannot verify this personally, because I do not live in the USA and have not been there for years.)
The blocking thing appears to be mostly a US issue, there are not many reports of such practices from other countries.
  Modem Issues with the Pinephone Temmie19 5 3,029 07-02-2025, 12:50 PM
  FOSS fw problem - PinePhonePro, EG25 modem dukla2000 5 2,566 02-05-2025, 02:30 AM
  power circuit can't charge battery and can't supply enough power for modem or wifi vortex 2 3,179 02-17-2024, 04:15 PM
Last Post: vortex
Bug PinePhone modem keeps "disappearing" Kevin Kofler 14 13,286 03-22-2023, 05:28 PM
  modem not working michelinux 0 1,865 02-16-2023, 04:56 AM
Last Post: michelinux
  modem not detected al_x 3 6,736 02-15-2023, 11:17 AM
Last Post: fxc
  PinePhone carrier support in Hungary notramo 7 6,046 12-14-2022, 12:18 PM
Last Post: notramo
  firmware udate Quectel EG25-G modem alwi 7 10,429 07-06-2022, 01:43 PM
Last Post: user641
  Need command to tell what modem firmware I am on. purpletiger 4 5,675 07-06-2022, 12:35 PM
  The modem does not recognize Korean SIM cards (what?) bdicewk 9 8,458 06-13-2022, 04:12 AM
Last Post: zetabeta
