Can't boot Pinephone Pro into Factory Test Build for Hardware Checking
I can't boot my newly received Pinephone Pro into the Factory Test Build for Hardware Checking linked to by the phone's wiki page. I've verified the md5 hash of the downloaded image, and tried two SD cards. The accompanying instructions on that wiki page seem to be out of date, referring to an "RE button" that is only on phones sold between January and July 2022, according to other sections of the same page. Here's the procedure I've pieced together for my phone and attempted:
  1. Download file and verify md5 hash.
  2. Gunzip it.
  3. sudo dd if=pinephone_pro_dd_android9_QC_Test_SDboot_20220215-8GB.img of=/dev/sdb bs=1M status=progress conv=fsync
  4. Put the SD card in the phone.
  5. Power on / buzz once.
  6. Hold volume down, wait for another buzz, and release.
  7. LED changes to blue.
  8. At this point it should boot from the SD card, but it buzzes and flashes red and yellow, and boots into the stock Manjaro with Plasma Mobile.
Is that image supposed to work with phones sold after July 2022?
And if so, are my above steps correct?
I'm able to boot into a postmarketOS image, so the trouble here is Pine64's Factory Test Build image. Is there a newer version of it?
I booted into it just fine. I received my pppro december 2023. You have to hold down that RE button pushed in while powering (insert charging cable or power-on button). You flash it to SD card, not eMMC btw
Tow-Boot on the SPI is probably not compatible with the factory test, which is why it worked with the RE button disabling the SPI.
Edit: I just checked and the manual says to hold the RE button.
  "USB access to SD" disappeared on a Pinephone Pro jebez 0 1,719 06-19-2026, 06:40 PM
Last Post: jebez
  what stopped pinephone pro? heocb 1 2,218 01-14-2026, 09:56 AM
  PinePhone Pro: Camera App very laggy Martin87 3 6,582 08-22-2025, 11:23 PM
Last Post: teekay
  PinePhone Pro discontinued teekay 9 19,096 08-22-2025, 11:19 PM
Last Post: teekay
Exclamation Pinephone Pro wont boot to anything! Supervisor 5 4,642 08-18-2025, 06:15 PM
  Pinephone pro ee bricked? dennylee 3 3,545 07-22-2025, 12:06 AM
Last Post: Dendrocalamus64
  No rk2aw boot menu jebez 7 5,399 07-09-2025, 07:12 AM
Last Post: mikehenson
  Full desktop Surfing and Absolute Privacy on the pinephone? Www 8 6,167 06-30-2025, 10:51 AM
  Backing up data on Pinephone Pro to hard disk, optical disk and flash? Www 4 4,333 06-29-2025, 02:46 PM
  Printing and scanning documents with pinephone? Www 4 4,431 06-29-2025, 11:48 AM
