Use the Linux Console with the PinePhone Keyboard
With the help of these two references, the console is usable with the PinePhone Keyboard, and the combination has the symbol row working with the Pinecone Key.
ludgate's help on the console
Modify the two files as ludgate describes.
xnux's help on the console symbols
For the symbol row, make the file ppkb.map:
#strings as usual
#compose as usual for "iso-8859-1"
#keymaps 0-63
plain keycode 125 = ShiftR
ShiftR keycode 125 = ShiftR
ShiftR keycode 0x02 = bar
ShiftR keycode 0x03 = backslash
ShiftR keycode 0x06 = asciitilde
ShiftR keycode 0x07 = grave
ShiftR keycode 0x08 = minus
ShiftR keycode 0x09 = equal
ShiftR keycode 0x0a = underscore
ShiftR keycode 0x0b = plus
then enter or automate:
sudo loadkeys ppkb.map
To automate, one could insert this into .profile
export XKB_DEFAULT_MODEL=ppkb
if [ $(tty) = "/dev/pts/0" ]; then
    tty
else
    tty
fi
Then the console is reachable by pressing Ctrl Fn Alt 2. The Phosh interface is at Ctrl Fn Alt 7, with more consoles in between.
It seems that the DanctNIX Arch images do not require this fix, but just the rotation. And the keyboard symbols also work under Wayland with Arch.
So, do DanctNIX Arch installations have a monopoly on supporting the PinePhone Keyboard, in both console and Wayland? I forget if Manjaro installations include DanctNIX.
  Pinephone (Pro) Keyboard Case for sale manubert 7 14,951 02-08-2026, 07:41 PM
Last Post: Ondy
  NEW pinephone keyboard case and LoRa backplate for sale ragele 0 653 01-12-2026, 06:09 PM
Last Post: ragele
  Replacement battery for PinePhone? j_s 9 5,950 06-03-2025, 04:19 PM
Last Post: j_s
  keyboard case charging but not typing new2pinephone 19 20,638 02-14-2025, 04:09 PM
Last Post: zltpxqhp69o2
  Searching for a PinePhone Keyboard Case RubiksCube 1 3,893 10-07-2024, 11:08 PM
  So which keyboard you suggest for the Pinephone? Peter Gamma 21 15,960 07-19-2024, 08:05 AM
Last Post: Peter Gamma
  Rii mini 4 keyboard and touchpad work over Bluetooth Peter Gamma 0 2,565 07-19-2024, 08:02 AM
  Keyboards for the PinePhone? Peter Gamma 1 4,104 07-04-2024, 10:22 PM
  Bring the Pinephone keyboard back, it is worth it! Peter Gamma 1 3,751 07-04-2024, 07:32 AM
Heart The Pinephone keyboard offers alternative layouts Peter Gamma 0 2,091 07-04-2024, 05:40 AM
