Bluetooth keyboard with trackpad
(05-10-2021, 04:39 PM)Zebulon Walton Wrote:
(05-10-2021, 09:39 AM)wibble Wrote: If the trackpad is anything like the one on the Rii mini i8 (not bluetooth but similarly small) it will be frustrating to use - a trackpoint would be much better, or a larger touch surface on the back of the keyboard. Not sure if anyone makes one with either of those though. Being Bluetooth 3.0 it should be fine so long as they've not gone for nonstandard quirks.
I received the keyboard today and it actually works quite well. No problem connecting to the Pinephone's built-in bluetooth. Touchpad action isn't bad considering the small size. Obviously on a small keyboard like this you won't be writing any novels but it's a heck of a lot better than the on-screen keyboard for using the terminal. About the only downside I see is with bluetooth enabled on the Pinephone battery life will be shorter.
@ Zebulon Walton
@wibble
thanks for sharing this. This also one of my favorite keyboard. I've used it for years and I was always happy with it, but I have not tested yet with the Pinephone. The Ri mini 4 is eventually also worth testing. It is Bluetooth and 2.4 Ghz with it's own dongle which is included. Just to have all the options checked which are available.
I ve read it if for instance the Pinephone keyboard is attached to the PP, it is only possible to one further Bluetooth device.
Is this also the case with the Ri mini 4 connected over 2.4 GHz with it's own usb dongle? Someone write here in the forum that with the PP keyboard he could not add and usb mouse.
I tested this keyboard with my Pinephone with PMOS and it disconnects.
The only keyboard which is confirmed to work with the Pinephone is the  ancient iGo Stowaway - no problems there, which was tested by wibble.
Now that Pine64 does not offer the Pinephone keyboard anymore it is the only keyboard which is left and confirmed to work I know.
Has someone another keyboard with the Pinephone he can confirm that it works reliably?
  Rii mini 4 keyboard and touchpad work over Bluetooth Peter Gamma 2 5,487 06-04-2026, 12:16 PM
Last Post: elinkser
  Pinephone (Pro) Keyboard Case for sale manubert 8 19,264 05-15-2026, 11:36 AM
Last Post: oliveira11670
  NEW pinephone keyboard case and LoRa backplate for sale ragele 0 2,996 01-12-2026, 06:09 PM
Last Post: ragele
  keyboard case charging but not typing new2pinephone 19 27,056 02-14-2025, 04:09 PM
Last Post: zltpxqhp69o2
  Searching for a PinePhone Keyboard Case RubiksCube 1 5,445 10-07-2024, 11:08 PM
  So which keyboard you suggest for the Pinephone? Peter Gamma 21 23,283 07-19-2024, 08:05 AM
Last Post: Peter Gamma
  Bring the Pinephone keyboard back, it is worth it! Peter Gamma 1 5,277 07-04-2024, 07:32 AM
Heart The Pinephone keyboard offers alternative layouts Peter Gamma 0 3,157 07-04-2024, 05:40 AM
  Keyboard & 2.4G usb dongle for the Pinephone? Peter Gamma 2 4,970 06-29-2024, 09:36 PM
  Was someone able to use the Pinephone keyboard & an usb mouse at the same? Peter Gamma 4 12,708 06-26-2024, 07:11 AM
Last Post: dachalife
