SATA hotplug not working?
I set up a NAS but I realized SATA hot plug is not working.
Is it a limitation of my SATA adapter or doesn't it work in general?
Looks like I got a ASM1166 chip, but this is odd because the chip got 6 SATA lines but my card has 8 sockets.
this adapter is not optimal because it uses only 2 PCIe-Lanes.
I probably should by a new one. it was cheap, though Wink
thanks
JPT
01:00.0 SATA controller: ASMedia Technology Inc. ASM1166 Serial ATA Controller (rev 02) (prog-if 01 [AHCI 1.0])
       Subsystem: ASMedia Technology Inc. ASM1166 Serial ATA Controller
       Flags: bus master, fast devsel, latency 0, IRQ 50
       Memory at fa080000 (32-bit, non-prefetchable) [size=8K]
       Memory at fa082000 (32-bit, non-prefetchable) [size=8K]
       Expansion ROM at fa000000 [virtual] [disabled] [size=512K]
       Capabilities: [40] Power Management version 3
       Capabilities: [50] MSI: Enable+ Count=1/1 Maskable- 64bit+
       Capabilities: [80] Express Endpoint, MSI 00
       Capabilities: [100] Advanced Error Reporting
       Capabilities: [130] Secondary PCI Express
       Capabilities: [170] Latency Tolerance Reporting
       Capabilities: [200] L1 PM Substates
       Kernel driver in use: ahci
  Which SATA card should I use my NAS server RAID5 Louysa 3 5,760 09-24-2023, 04:40 AM
Last Post: JPT223
  SATA keeps crashing JPT223 1 4,438 09-21-2023, 10:52 PM
  Compatible PCIe Sata Controller spacebricker 1 5,481 02-06-2023, 10:03 AM
Last Post: diizzy
  ROCKPro64 with 16 ports SATA controller ZeblodS 19 49,868 12-18-2022, 06:25 PM
Last Post: heyghoge
Bug Anyone else's UART RX (serial input) stopped working? pion 1 5,565 04-07-2022, 08:35 PM
Last Post: foresto
  Existings disks and using a StarTech SATA Controller jkugler 1 4,729 12-09-2021, 06:41 AM
Last Post: SVDSHRDJD
  Rockpro64 Sata Card kills itself jerry110 33 77,772 10-20-2021, 04:36 AM
Last Post: fieni
  Right direction SATA card corax 2 6,656 09-15-2021, 12:46 PM
Last Post: corax
  Won't boot with SATA card rjzak 4 10,595 01-09-2021, 05:56 PM
Last Post: kuleszdl
  SATA issues machina 25 59,189 10-16-2020, 12:16 PM
Last Post: lrb
