Use the Linux Console with the PinePhone Keyboard
With the help of these two references, the console is usable with the PinePhone Keyboard, and the combination has the symbol row working with the Pinecone Key.
ludgate's help on the console
Modify the two files as ludgate describes.
xnux's help on the console symbols
For the symbol row, make the file ppkb.map:
#strings as usual #compose as usual for "iso-8859-1" #keymaps 0-63 plain keycode 125 = ShiftR ShiftR keycode 125 = ShiftR ShiftR keycode 0x02 = bar ShiftR keycode 0x03 = backslash ShiftR keycode 0x06 = asciitilde ShiftR keycode 0x07 = grave ShiftR keycode 0x08 = minus ShiftR keycode 0x09 = equal ShiftR keycode 0x0a = underscore ShiftR keycode 0x0b = plus
then enter or automate:
sudo loadkeys ppkb.map
To automate, one could insert this into .profile
export XKB_DEFAULT_MODEL=ppkb if [ $(tty) = "/dev/pts/0" ]; then     tty else     tty     sudo loadkeys ppkb.map fi
Then the console is reachable by pressing Ctrl Fn Alt 2. The Phosh interface is at Ctrl Fn Alt 7, with more consoles in between.
It seems that the DanctNIX Arch images do not require this fix, but just the rotation. And the keyboard symbols also work under Wayland with Arch.
So, do DanctNIX Arch installations have a monopoly on supporting the PinePhone Keyboard, in both console and Wayland? I forget if Manjaro installations include DanctNIX.
  Rii mini 4 keyboard and touchpad work over Bluetooth Peter Gamma 4 6,390 11-09-2026, 10:04 PM
Last Post: noahclark
  Pinephone (Pro) Keyboard Case for sale manubert 8 19,940 05-15-2026, 11:36 AM
Last Post: oliveira11670
  NEW pinephone keyboard case and LoRa backplate for sale ragele 0 3,562 01-12-2026, 06:09 PM
Last Post: ragele
  Replacement battery for PinePhone? j_s 9 11,731 06-03-2025, 04:19 PM
Last Post: j_s
  keyboard case charging but not typing new2pinephone 19 28,289 02-14-2025, 04:09 PM
Last Post: zltpxqhp69o2
  Searching for a PinePhone Keyboard Case RubiksCube 1 5,783 10-07-2024, 11:08 PM
  So which keyboard you suggest for the Pinephone? Peter Gamma 21 24,787 07-19-2024, 08:05 AM
Last Post: Peter Gamma
  Keyboards for the PinePhone? Peter Gamma 1 5,716 07-04-2024, 10:22 PM
  Bring the Pinephone keyboard back, it is worth it! Peter Gamma 1 5,627 07-04-2024, 07:32 AM
Heart The Pinephone keyboard offers alternative layouts Peter Gamma 0 3,436 07-04-2024, 05:40 AM
