PineTab2 virtual keyboard: symbols instead of numbers
Hello! I'm having a bug with the PineTab2 virtual keyboard (Maliit) with two different Flathub packages (ungoogled-chromium and Xlog).
When I press a number with the virtual keyboard, the "shift" version of that number is actually entered into the UI. For example, when pressing 3, # is entered, or 4, $ is entered, etc.
I've left the state of the PineTab2 largely unchanged since receiving it — no major OS changes, etc.
Is anyone else able to reproduce this? If yes, where's the correct place to report this bug? Thanks!
I have the same problem with the vitual keyboard
(06-14-2023, 07:14 AM)clemfandango Wrote: Hello! I'm having a bug with the PineTab2 virtual keyboard (Maliit) with two different Flathub packages (ungoogled-chromium and Xlog).
I have the same for Firefox. Installed with pacman, not flatpak. Also I am using Plasma Mobile, not sure if that is relevant.
I have the suspicion now that it might be that the affected apps run X11 instead of Wayland?
i have set one parameter to start Firefox in Wayland mode and the keyboard issue as well some other niggles disappeared. Still no idea how to fix the other apps, but it might be worth investigating.
Great information, switched chromium and Firefox to Wayland mode and and it worked like a charm
I am using Brave browser; Wayland flag worked great for a while. Problem seems to be back with Brave v1.52.130.
Suggestions?
  Castle Game Engine on PineTab2 now officially available michalis 3 4,966 02-24-2026, 04:39 PM
Last Post: michalis
  Customize virtual keyboard? WEF 6 3,540 01-19-2026, 02:16 PM
Last Post: WEF
  No updates on pinetab2 arch danctnix? Ingen 8 5,422 10-16-2025, 02:57 AM
Last Post: TcCoy
  keyboard pogo pins part number starpp 0 4,878 08-26-2025, 04:34 AM
Last Post: starpp
  Libre Office on Pinetab2? Anonymous1989 1 2,218 08-07-2025, 09:50 PM
  Pinetab2: (multi)boot normal image on eMMC and some OS on SD- card Bart 4 7,582 05-31-2025, 02:34 PM
Last Post: stevepaesani
  New pinetab2 - can't charge it tmhorne 10 10,171 05-13-2025, 12:42 PM
Last Post: tmhorne
  PInetab2, Limit battery charge to less than 100%? rqkeating 0 2,714 06-30-2024, 08:54 PM
Last Post: rqkeating
  New PineTab2 dRateNWAytORy 2 4,883 05-11-2024, 09:46 AM
Last Post: frtodd
  Someone is interested for a PineTab2 8GB in Mexico? genobraker 0 2,661 03-06-2024, 07:22 PM
Last Post: genobraker
