I am using xubuntu-xenial-mate-20160528-longsleep-pine64-8GB.
How to enable XDMCP remote connections on the Pine64?
thanks!
thanks!
How to enable XDCMP on longsleep Xubuntu?
How to enable XDMCP remote connections on the Pine64? thanks!
06-09-2016, 04:27 AM
Hey
Not sure about XDMCP - never used it - but I know that VNC works just fine on the pine as I've helped a user set it up in some time ago. sudo apt-get install tightvncserver Cheers
06-11-2016, 10:40 AM
(06-09-2016, 04:27 AM)Luke Wrote: Hey Thanks for the suggestion. XDMCP is native to linux and unix-like systems to export the video through the network. But maybe VNC is a better idea. I will try, thanks.
06-12-2016, 11:33 PM
I would assume that you want to export X11 to view X apps running on your local machine.
I've successfully done this on my Mac, but it should work on any platform that has X11 binaries for it On the host: Windows - install Xming https://sourceforge.net/projects/xming/ Mac - install XQuartz https://www.xquartz.org/ On pine (assuming you have working X11 env): run 'xhost+' to enable all connections should give you a message akin to "all connections are now permitted" On your host: 1. Run X server you installed 2. SSH to Pine with -X, if using command line or if using Putty, expand SSH tab and select X11 forwarding to enable That's it. To test, run xeyes ;-)
06-17-2016, 06:17 PM
(06-12-2016, 11:33 PM)gwizard Wrote: I would assume that you want to export X11 to view X apps running on your local machine. Acutally I wanted to use an Xserver program such as Xming to connect directly to the Pine64 and get the login screen. to export video i know how to do it
06-20-2016, 06:48 AM
(06-20-2016, 06:48 AM)MacFizz Wrote:I second xrdp. I use it along with bitvise on my windows machine and it works like a charm.(06-08-2016, 09:08 PM)melao Wrote: I am using xubuntu-xenial-mate-20160528-longsleep-pine64-8GB. |
| Gentoo for pine64 - longsleep kernel | incoherent | 0 | 5,615 |
12-09-2017, 08:14 AM Last Post: incoherent |
| [How-To] Make PINE 64 with Ubuntu Xenial Longsleep build crunch BOINC Tasks | moisesmcardona | 3 | 12,178 |
07-27-2016, 01:16 PM Last Post: NexusDude |
| longsleep installed headers for dkms usage | Faye | 4 | 9,073 |
06-15-2016, 05:04 PM Last Post: xalius |
Longsleep magic ! | Lutinmalin | 6 | 14,877 |
06-08-2016, 05:54 PM Last Post: texadactyl |
